July 31, 2012, 15:23 |
CFX Solver error
sunil
Rep Power: 13 |
Hello sir,
i am getting the following error when i changed the mesh size (spacing 0.05 to 0.005 and ratio 2 to 1.2) ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | *** Run-time memory allocation error *** | | Not enough free memory is currently available on the system. | | Could not allocate requested memory - exiting! how to fix this problem |
July 31, 2012, 19:10 |
Rep Power: 143 |
The problem is pretty obvious - you have run out of memory.
Options include: * Get more memory * Run parallel * Turn physics off to make the model smaller * Run single precision (if you are running double precision) |
error #001100279 |
Problem running perturbUCyl | sen.1986 | OpenFOAM | 17 | June 4, 2019 05:56 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 17:38 |
