April 21, 2011, 18:07 |
ANSYS CFX solver exited with return code 2
Ugly Kid Joe
Does any one know the "Return code 2 error" ?????????????
Thank you |
April 26, 2011, 22:10 |
Rep Power: 143 |
Unfortunately CFX has lots of undocumented error codes. You have to read the error in the context of what is happening at the time. Can you post the out file around the error message?
April 26, 2011, 23:02 |
Ugly Kid Joe
In my FORTRAN subroutine I had assumed that NLOC is 1 so I had defined the O/p as RET(1,1). I rectified it later. Thanks though.
One more question: http://www.cfd-online.com/Forums/cfx...using-cfx.html Thanks |
July 25, 2011, 15:46 |
Jean-François Morissette
Hi Vmlxb6,
I have the same problem you had, with a return code 2 using fortran subroutine. I also asume that my output is only RET(1,1). It is not? How do you know what is NLOC value? And how do you solve your probleme exactly? You just said you rectified it but how? Thank you! |
July 25, 2011, 16:01 |
Ugly Kid Joe
So I used the loop the way they use it in the Air-conditioning tutorial. Just parameters like Nloc is all determined by CFX.
Hope that helps |
July 26, 2016, 09:05 |
ANSYS Solver terminated unexpectedly with return code 1792
Amir Ibrahim
I am getting the Return 2 exit error along with +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | ANSYS Solver terminated unexpectedly with return code 1792 | +--------------------------------------------------------------------+ I am trying to run a steady state two-way FSI simulation by coupling CFX and Transient Structural using Ansys Multi-field (MFX). I have checked the error message and it contains no useful information. All it says is "/COM,ANSYS RELEASE Release 17.1 BUILD 17.1 UP20160404 13:53:26 " Has anyone managed to fix that error? Thanks! Amir. |
June 22, 2017, 18:01 |
#7 | |
srcredchi
Rep Power: 8 |
Did you solve the problem? I am getting same error. |
Compressible Flow in Ansys CFX | bcheruk | CFX | 15 | July 6, 2017 06:30 |
Error message CFX Solver | Fatnes | CFX | 25 | July 3, 2015 10:32 |
CFX solver error | kh_thakor | CFX | 3 | January 11, 2011 16:39 |
Exporting results from CFX to ANSYS ?? | sohail ahmed | CFX | 1 | December 20, 2007 01:10 |
MFX: weired force transfer from cfx to ansys | zyf | CFX | 3 | October 7, 2006 03:08 |
