April 24, 2011, 11:42 |
CFX setup for opposing jet
Madhusanka Herath
Rep Power: 15 |
Hi everyone,
I want to put a opposing jet for a blunt body which runs in supersonic flow in CFX. When ever I try to run for different speed for example free stream 2Mach and opposing jet 5Mach it keeps crashing for steady case. Any help would be appreciate. Thank you very much for your time. |
April 26, 2011, 22:02 |
Rep Power: 143 |
It can be tricky to get convergence with supersonic flows. Try using local timescale factor to start convergence off before switching back to physical time scale to finish the run to convergence.
Also try the expert parameter which does two loops of the mass/pressure equation per coefficient loop to make conservation tighter, that can also help. |
2D Plane Jet Fluent Solution | doug | Main CFD Forum | 11 | February 4, 2019 09:34 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
Guide setup PVM CFX | painterwolf | CFX | 12 | May 24, 2009 19:47 |
Can CFX deal with jet impinging problem? | prayskyer | CFX | 1 | September 4, 2006 17:04 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
