heat flux distribution
Old   April 25, 2011, 07:37
Default heat flux distribution
George Theo
gtheo is on a distinguished road
Hello
I'm using ANSYS CFX v13 to simulate the fluid flow and conjugate heat transfer in a rectangular duct. I want to plot the heat flux distribution on the duct bottom wall, so -in CFD post- I create a line on the bottom wall and plot the built-in variable "Wall heat flux". The results I'm getting show that the heat flux is zero everywhere, which is not true (obviously!). I followed the exact same procedure in ANSYS CFX v11 and the flux distribution I got was perfectly normal.
It seems that I should do something different in CFD-post v13 in order to get the heat flux distribution. Any suggestions?
Thank you in advance!
gtheo is offline   Reply With Quote
Old   April 26, 2011, 22:00
Are you sure your line is on the wall? Wall heat flux only exists at the walls so if your line is not on the wall it will not return values.
Old   April 27, 2011, 03:36
George Theo
I checked the line and it is on the wall. The odd thing is that I get values for the wall heat flux, but they are all equal to zero. If the line is placed anywhere else than the wall, I don't get any values at all, which is logical.
Total heat transf. rate vs Total surface heat flux Renato Sousa FLUENT 1 April 14, 2020 03:27
Sign of Heat Flux at wall Kyung FLUENT 2 February 26, 2016 16:25
Heat Flux Wall Boundary Confusion. Joee FLUENT 1 August 21, 2010 12:20
Wall Heat Flux not a listed variable mike CFX 8 February 5, 2009 13:32
Customize Heat Flux Distribution Using UDF Ken Adams FLUENT 0 May 25, 2007 15:25
