CEL problem
Old   May 1, 2011, 16:45
Default CEL problem
Julio Mendez
juliom is on a distinguished road
Send a message via Skype™ to juliom
Hello my dear collegues.
I have been working on an oil and gas separator, but I have not had any result of my CFX.
I do no know where are my mistakes here I let you some information about it:
Boundaries conditions
Inlet: mass flow rate of each phase
Multiphase model: mixture
Outlet:
upper outlet: opening
bottom outle: opening
The other problem is that I defined some CEL, at the outlet I defined: massflow()@outlet. but it gave a straight line in the output file..
It seems that the program is not computing any flow mass at taht opening..
SOME SUGGESTIONS?
juliom is offline   Reply With Quote
Old   May 1, 2011, 18:47
You have not described what you are modelling. What type of openings aer you using for the outlets? Is your model converged? What straight line are you getting for the mass flow results?
Old   May 2, 2011, 08:40
Julio Mendez
Yes I did, I am modeling a vertical oil - gas separator.
The openings are " open pressure for entreinment"
The line is a straight line which indicates 0 , it seems that the mass flow is zero, it is imposible
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Incoherent problem table in hollow-fiber spinning Gianni FLUENT 0 April 5, 2008 10:33
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Problem in Tutorial problem of fluent Phanindra FLUENT 5 April 17, 2007 09:57
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
