April 17, 2016, 04:44 |
Monitoring Pressure Drop
Rahul
Rep Power: 10 |
I want to simualte air flow pattern in a muffler.For that i will monitor value of pressure drop between the inlet and the outlet
Turbulence Model-SST Fluid-Air at 25 Degree Celsius Boundary Conditions: mass flow rate-inlet-0.2194kg/sec pressure-outlet-Relative static pressure is set to 0 Pa I defined a expression in CFX as areaAve(Pressure)@REGION:INLET-areaAve(Pressure)@REGION:OUTLET Now what my problem is CFX reports the value of Pressure drop to be 1.2E-08 !! Could anybody please help me in this regard? Last edited by raghulvr; April 18, 2016 at 21:18. |
April 17, 2016, 06:31 |
Rep Power: 143 |
This is an FAQ: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
Some possibilities: * What units is the 1.2e-8 in? * Did you set the flow rate and geometry size correctly? * What is the dynamic head at the inlet and outlet? Does that explain the difference? * Otherwise the FAQ lists lots of other issues. Inadequate mesh resolution is the problem in 95% of questions on accuracy in my experience, by the way |
April 17, 2016, 08:42 |
Rahul
Rep Power: 10 |
Thank you so much for the reply
I have given all the details regarding my simulation Last edited by raghulvr; April 18, 2016 at 21:21. |
April 17, 2016, 08:48 |
Rahul
Rep Power: 10 |
the difference in dynamic head between inlet and the outlet is 4.700KPa-this is result given in the literature
April 20, 2016, 02:19 |
Rokson K Mathew
Rep Power: 10 |
I would suggest a pressure inlet, mass flow outlet
inlet pressure- 1 atm (101325 Pa) To monitor pressure drop in the system, Total Pressure would do fine. (massFlowAve(Total Pressure in Stn Frame )@Inlet - massFlowAve(Total Pressure in Stn Frame )@Outlet) Try using this expression Cheers! |
April 24, 2016, 12:06 |
Rahul
Rep Power: 10 |
Thank you so much for your inputs Mathew
Cheers! |
cfx, muffler, pressure drop |
How to plot pressure drop with Periodic BC? | bigfans | FLUENT | 7 | November 8, 2016 11:28 |
Pressure drop using Fan type BC | Alexis Sack | OpenFOAM Running, Solving & CFD | 2 | September 22, 2014 09:18 |
How to study pressure drop of continous phase in VOF model | sajeesh | FLUENT | 4 | February 5, 2014 22:01 |
Pipe Flow - Pressure Drop | Daniel L | FLOW-3D | 2 | December 10, 2010 04:23 |
Pressure Drop at entrance of a rotor-stator. | Resnick | Main CFD Forum | 0 | November 20, 2007 14:50 |
