from single passage to full annulus
Hi All,
I. doing calculations of a single passage of Rotor 67 and afterwards for some reason I need to have a result file .res which contains the full annulus solution. Is there anyhow to transform the single passage solution obtained with CFX to the full annulus? In this way I should get an initial file where the solution will be periodic. Thank you in advance |
