is there a way to parametrize the angle of attack |
May 19, 2011, 07:03 |
Nick
Rep Power: 15 |
Hi all,
I would like to know if it's possible to define the angle of attack for airfoil flow simulation as a parameter so cfx would run in a series consecutively |
May 19, 2011, 07:39 |
Rep Power: 143 |
Yes, it is possible.
May 19, 2011, 07:42 |
Nick
Rep Power: 15 |
Thanks. Could you let me know how it's done please?
May 19, 2011, 08:11 |
Rep Power: 143 |
Using parametric modelling in workbench. Look at the workbench tutorials for how to do this.
May 19, 2011, 22:29 |
Xu xing
You can write a CFX-Pre macro,and change the parameter every time you run the macro.
May 20, 2011, 06:14 |
Stuart
Rep Power: 25 |
Isn't a macro more work than is necessary?
Glenn said about the parameter feature in Workbench, so can you just run the required freestream velocity components (to give your required angles of attack) through that? |
CFX convergence problem simulating ogive-cylinders at varied angle of attack | jdacosta | CFX | 6 | February 25, 2015 21:42 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
introducing angle of attack on ICEMCFD HEXA | icem beginner | Main CFD Forum | 3 | December 17, 2008 05:05 |
angle of attack with icem hexa | icem beginner | Main CFD Forum | 0 | December 5, 2008 16:54 |
angle of attack | kiran | FLUENT | 0 | September 10, 2004 08:18 |
