May 30, 2011, 05:10 |
Axisymmetric 2D mesh adaptation - ERROR
Josef
does the 'mesh adaptation' work with 2D axisymmetric approach in CFX? When 1) I import 2D mesh as FLUENT (*.msh) --> axisymmetric the solver works properly 2) I import (the same) 2D mesh as FLUENT (*.msh) --> axisymmetric. Then I set up the 'Mesh adaptation' in Pre, the solver returns following error: A negative ELEMENT volume has been detected.... after the adaptation. 3) I import (the same) 2D mesh as FLUENT (*.msh) --> PLANAR. Then I set up the 'Mesh adaptation' in Pre, the solver works properly. I don't know where the problem is.... Is there any system variable needed to be set? I use CFX 13 Thank you for replies Last edited by Pepe; May 30, 2011 at 06:54. |
May 30, 2011, 06:23 |
Rep Power: 143 |
Mesh adaptation was dropped as a CFX feature a few releases ago and to my knowledge has not returned. Also using Fluent to refine meshes then importing them into CFX-Pre is problematic, I have never got it to work for me.
May 30, 2011, 07:52 |
Josef
Thank you Glenn for a quick reply.
My mesh was built in Gambit and imported directly to CFX (I didn't use Fluent before). I suppose, import was successfull, because solver converged OK. But the 'mesh adaptation' could cause the problems. Is possible, that the adaptation algorithm is not able to operate with the small angle segment, which appears due to axisymmetric import?? I'm gonna to compute a lots of variants, so I prefer CFX to Fluent. |
May 30, 2011, 08:28 |
Rep Power: 143 |
Fluent has a "real" 2D solver, so if you have the choice of both solvers I would use Fluent if you have lots of simulations to do.
adaptation, axisymmetric, cfx 13, mesh |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 17:38 |
