Home > Forums > CFX
help
Old   June 1, 2011, 10:55
Default help
xiaobao jia
xiaobao_jia is on a distinguished road
Hello;
I have to modify the velocity of every node in every iteration like ux+5, Uy-2, Uz+0, how can I use cel to fix it? any ideas? thanks a lot.
regards
jia
xiaobao_jia is offline   Reply With Quote
Old   June 1, 2011, 18:31
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
You cannot do this in CEL. And I cannot see why you would want to do it anyway, there is no way this is going to converge.
What are you trying to do?
Old   June 2, 2011, 09:47
xiaobao jia
thank you Mr. Glenn Horrocks, you are the guy I need to ask this question.
I am simulating a rotating airfoil, what I like to do is that I will put -w*r term in the convective term and diffusion term through velocity variations. I do think this is physics simulation of this problem rather than rotating mesh or domain.
Do you think I can fix this in cfx with user function?
regards
xiao
Old   June 2, 2011, 19:18
You cannot do this by simply adding and subtracting velocity components!
Use the built-in rotating frame of references to do this. Of if this is not suitable please explain why not.
Old   June 3, 2011, 11:03
xiaobao jia
Hi Mr. Glenn
This material is interesting, I will try this. Then I will inform you the result.
thanks
xiao
Old   June 13, 2011, 10:58
xiaobao jia
Hi; Mr. Glenn
I think this method is only valid for Euler equation ( inviscid solution), because rotation velocity can not give full or a part of natural boundary layer velocity.
regards
xiao
Thread Tools
Trackbacks are On
