Initialisation Temperatures
Old   June 1, 2011, 09:00
Default Initialisation Temperatures
Harsh Bansal
harsh.bansal is on a distinguished road
The geometry for my problem is :
These are concentric cylinders with the solid(thick) part denoted by '=' sign.
i.e. There are two diameters for inner-cylinder (solid part in between) and one outer diameter.
I have just started using CFX
I am finding some initialisation temperatures as troublesome like :
In the Solid Domain initialisation its asking for some temperature value after choosing the option as Automatic with value.
Also, in the Fluid Domain, if i am giving the boundary type as opening for inner-fluid outlet as well as for outer fluid outlet, it asks for an opening temperature.
I just wanted to know what these temperatures mean and what values should they be assigned ?
I am attaching a .txt file providing the various conditions that i have given.
If anyone knows it then please do reply.
Thanks...
harsh.bansal is offline   Reply With Quote
Old   June 1, 2011, 11:42
A.R. Baserinia
baserinia is on a distinguished road
Please read the documentation first. The answers are explained there.
1) Automatic with value means you must supply a value. If you don't want to do so, just choose automatic.
2) An opening boundary condition is for cases that you're not sure about the flow direction. For an outlet, use outlet boundary condition.
baserinia is offline   Reply With Quote
Old   June 2, 2011, 01:07
Harsh Bansal
Hello baserinia,
Thank you for your reply.
For the Solid domain initialisation temperature, I wanted to know what the Automatic with value means.
Means what that value of temperature signifies (Its physical significance).
I know that it wouldn't ask me for a temperature value if I have given it as Automatic.
Thanks...
Old   June 2, 2011, 13:18
A.R. Baserinia
The value is your initial guess for the temperature field. If you can come up with a good guess, the solution converges faster and more robustly.
Old   June 3, 2011, 01:50
Harsh Bansal
Thank you baserinia
Can you tell me when we give the Solid domain initialisation temperature as Automatic, then is there any place where we can see what value has been given assigned to that temperature ...
Old   June 3, 2011, 12:14
A.R. Baserinia
The automatic temperature would be an area weighted average of boundary temperatures. You can turn of the energy equation, set the maximum iterations to 1 and look at the temperature distribution in the Post.
Excessively high temperatures brossofor FLUENT 0 June 2, 2010 02:53
[CFX] How to avoid negative temperatures? rogbrito CFX 3 February 15, 2010 05:59
modify ccmp for initialisation Thomas Baumann Siemens 4 August 24, 2009 09:35
Solve for two or more "Temperatures" Rui CFX 12 September 9, 2008 21:58
Domain initialisation. KM CFX 2 October 12, 2007 15:27
