June 1, 2011, 11:49 |
Transient heat flow
Rep Power: 17 |
I'm totally new to transient simulations. I had a newbie question. I was simulating the air flow inside a power amplifier cabinet which had Fans, Power sources and power amplifiers inside.
The power emanation from the amplifiers is of a transient nature and is described by the following details: Output Power = 200 W Duty cycle: Transient attribute:Gaussian, Total pulse duration: 6400 ms So I see that I need to consider 6400 ms as the total time with a time step of 400 ms. But this is something relevant to a single duty cycle so will it be fine to analyze the heat flow inside the cabinet just for a single duty cycle on these lines. Can some one please suggest me regarding this.
Best regards, Santhosh. |
June 1, 2011, 18:29 |
Rep Power: 143 |
In most electronics heat modelling things of this time scale can be averaged out and the avergae heat load used. So I would average the heat load out and apply a constant heat load. But if you are doing a transient simulation anyway then it is easy to apply the transient heat load.
June 7, 2011, 12:02 |
Rep Power: 17 |
Glenn could you please tell me how to calculate this average heat load. I apologize for raising such novice question but my experience is really too limited in this.
June 7, 2011, 19:00 |
Rep Power: 143 |
Integrate the heat load over a long time. If it is 11W for 1s and then 1W for 4s, and then repeats that pattern forever, then integrating over the full 5s cycle gives (11*1+1*4)/5 = 3W average load.
transient result in spray reactor with swirl flow | glenn creten | Main CFD Forum | 1 | August 14, 2012 05:10 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Heat Transfer boundary conditions for engine coolant flow simulation | rajuks | Main CFD Forum | 0 | February 15, 2010 09:04 |
Flow around pipes - heat transfer coefficient on the wall of pipe | doodek | Main CFD Forum | 2 | November 23, 2009 08:48 |
time averaged heat transfer in oscillating flow | Matthieu Ubas | Main CFD Forum | 2 | November 5, 1999 14:20 |
