June 27, 2011, 03:32 |
continuing to solution
Rep Power: 15 |
Hello everybody,
I've been working with Ansys-CFX about a transient heat transfer problem. I start to solve a problem and it takes at least 5 or more days (sometimes a month). If there's any trouble in computer system or the electircity (when computer shuts down or something..) I cannot get the result file and I have to start to the solution over! And it's just the waste of time! When I look at the working folder, there are trn. files. Can I use these trn files and continue to the solution from the time last trn file being created. |
June 27, 2011, 04:24 |
Lance
Rep Power: 22 |
June 27, 2011, 06:15 |
the procedure
Rep Power: 15 |
June 27, 2011, 06:46 |
#4 | |
Lance
Rep Power: 22 |
In the solver manager: Initial values specification/File Name: "your last .trn file" Continue history from: initial values or, using the command line cfx5solve -def $deffile -continue-from-file $inifile where $deffile and $inifile is defined as your definition file and trn file, respectively. |
June 27, 2011, 08:06 |
doesn't work
#5 | |
Rep Power: 15 |
I can't use these steps. I already tried this way, but the computer didn't restart normally.. It gives following error message and doesn't start to solve; ''the simulation terminated with errors. run concluded at Mon 27. No results are available!'' So I've been solving the problems which takes long time (1 month or more) by seperating the time. For example if I have 120 seconds run, I solve the problem with 10 sec parts. But I couldn't get a solution any further than that! If you have any suggestion, I'd be happy? |
June 27, 2011, 08:13 |
Lance
Rep Power: 22 |
This error message is useless, it doesnt tell us anything about what went wrong. Post the error message in the output from the solver instead (look in a file called "something"_001.out).
June 28, 2011, 07:06 |
the file
#7 | |
Rep Power: 15 |
error .txt |
June 28, 2011, 07:14 |
Lance
Rep Power: 22 |
Thats all? Error creating namemap: G/BCS missing ?
Two things: When you are saving the .trn files, do you only save a few selected variables or "standard". If you only save, say, temperature and HTC then the trn file does not contain enough data for a restart and it will fail. Could this be the issue? Also, avoid spaces in folder and file names. |
June 28, 2011, 09:50 |
save backup
#9 | |
Rep Power: 15 |
But I guess there's another way. I use the 'save backup file' option while the simulation's running. Therefore I can use this backup file as a result file, and continue to the solution from the intermediate time. But choosing all the variables may help. I'll write if it works.Thank you. |
June 28, 2011, 10:53 |
it works!
#10 | |
Rep Power: 15 |
Thank you. |
Integrated conjugate heat transfer solver in OpenFOAM | hjasak | OpenFOAM Running, Solving & CFD | 172 | April 13, 2023 00:42 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
solution singularity | litonx | OpenFOAM Running, Solving & CFD | 1 | February 21, 2007 01:32 |
Mesh independent solution | CFX Begineer | CFX | 0 | October 27, 2002 10:54 |
Discussion about Mesh independant solution | Seb | Main CFD Forum | 13 | May 22, 2001 13:37 |
