double precision
Old   June 13, 2011, 04:27
Default double precision
hsn
hasan amini
hsn is on a distinguished road
Dear friends,
I am dealing with a simple hydrodynamic problem of water flow in milichannels. my simulation is transient and as it is obvious, with relatively small dimensions. I checked with the documentation to see whether it is recommended to use double precision for calculations when you are dealing with small dimensions and I saw nothing.
Do you think I should use double precision?
my domain is a duct, 1mm long with a 0.3mm*0.3mm cross section...
thank you.
hsn is offline   Reply With Quote
Old   June 13, 2011, 06:19
Siassei is on a distinguished road
you should use double precision for all calculations. A double precision calculation use a 64 bit floating point number. A not double precision calc. use a 32 bit floating point number. Today, our FPU (floating poitn unit) deals with 11xbits (normaly).
64 bit numbers increase the robustness and stability of your calculation.
Siassei is offline   Reply With Quote
Old   June 13, 2011, 07:05
I do not agree that you should use double precision for all calculations. I routinely use single precision for MEMS simulations where the domain size is around 10um by 10um.
The key thing is the range of scales. If everything is small then single precision is probably OK. If some thing are small and some large then you probably need double. If you just want to be sure and don't mind about longer run times and have lots of memory then just use double anyway.
ghorrocks is online now   Reply With Quote
Old   June 13, 2011, 16:04
Ok, I agree with you. I'm not a CFX expert, but what units use CFX in the background of a calculation? Is the unit system fixed (e.g length in m and mass in kg) or use CFX-Solve the units, that are enabled (in the GUI of) in CFX-Pre?
Ok, next. If the domain is 10 by 10 um and the velocity of the fluid is 10 m/s. What you are use?
A question.
How big is the difference of time cost by our cases?
Old   June 13, 2011, 19:14
By default CFX uses SI units internally (m-kg-s-K). But it can use any internally consistent set of units.
What do you mean by "What you are use?"
Double precision generally adds about 50% to the simulation time and memory requirements providing the equivalent single precision simulation converges equivalently. If the double precision simulation improves convergence (that is, numerical accuracy was a problem for the single precision run) then the double precision run may be faster.
Old   June 13, 2011, 23:05
hsn
hasan amini
thank you ghorrocks and Siassei. I believe that double precision should be used when you are dealing with high aspect ratios. Thus what Siassei is pointing out is that: for example when your velocity is 1m/s but your smallest dimension is 0.1mm, the ratio of these two is 10e4 which is high(?) and we should use double precision... is my conclusion right, Siassei?
Old   June 13, 2011, 23:18
You cannot take a ratio of velocity and distance to give a meaningful number. The important ratio is of the largest and smallest important dimension, or the largest and smallest velocity or the largest and smallest pressure (relative to the reference pressure).
double precision
Continuing User Defined Real Gas Model issues aeroman FLUENT 6 April 8, 2016 03:34
Parallel User Defined Real Gas Model aeroman FLUENT 4 July 1, 2015 06:09
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
what's wrong about my code for 2d burgers equation morxio Main CFD Forum 3 April 27, 2007 10:38
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
