Total Presure Ratio in Rotor 37
Old   June 19, 2011, 23:21
Question Total Presure Ratio in Rotor 37
BalanceChen is on a distinguished road
Hi all, I am simulating the flow in the Rotor 37 and compare the results to the experimental ones. But who can tell me how should I do the average, by mass flow average or area average, in order to be consistent with the experimental results.
Lots of thanks,
BalanceChen
BalanceChen is offline   Reply With Quote
Old   June 20, 2011, 18:39
Use the same as the experimental results. What result are you comparing to and how was it calculated.
Old   June 20, 2011, 21:18
But i found no comments on how the experimental results averaged...
Old   June 20, 2011, 21:29
I take a test by using both area average and mass flow average to get the total pressure ratio, found the difference between is very little, about 0.01. So, there may be not a big problem here on which average method is used.
pressure eq. "converges" after few time steps maddalena OpenFOAM Running, Solving & CFD 69 July 21, 2011 07:42
Total pressure in CFX famarcfd CFX 0 June 17, 2011 10:33
ratio of total heat flux and radiative heat flux S.Karthikeyan FLUENT 2 July 1, 2008 03:48
diesel spray combustion equivalence ratio usker Siemens 12 March 1, 2008 06:09
Total pressure to static pressure ratio roadracer Siemens 1 April 17, 2003 05:31
