Parameteric Studies
Old   June 17, 2011, 08:32
Default Parameteric Studies
Frank Weise
FrankW is on a distinguished road
Hi
is there a possibility to get a access to the Desgin Parameters from the DM in CFX-Pre or CFD-Post?
E.g. i will simulate an tube. In DM, i design an section of the tube with an angel x and in cfd post i would like calculate the massflow of the whole tube so i need the angle x (360°/x*massflow). Or is there an other way to calculate the total massflow
best regards
Frank
FrankW is offline   Reply With Quote
Old   June 17, 2011, 08:45
If you evaluate an expression in CFD-Post which determines your flow rate and set it as a parameter it can then be used as a parameter in workbench.
Old   June 18, 2011, 04:25
Thumbs up
Frank Weise
Thanks, this is a good advice, it works fine . To this one i have a small problem. In one equation WB tolds me i've an error in unity. Because it isn't possible (speed*unitless should be speed). And sometimes i've got the right value. Could be a bug? I use Ansys 13 SP2.
So back to the original question, is there also a direct access to DM variables in CFX-Pre or CFD-Post?
Old   June 18, 2011, 07:22
The way to pass variables from DM to Pre and Post is through WB. Looks like you have a problem with the way you set the variable up. Also I have no idea what your comment "In one equation WB tolds me i've an error in unity. Because it isn't possible (speed*unitless should be speed). And sometimes i've got the right value." means.
case studies, vortex shedding cylinder Allan Cross FLUENT 2 May 30, 2005 14:13
Vortex shedding case studies Allan Cross FLUENT 5 May 30, 2005 14:06
Analytical studies instead of computational Ben Main CFD Forum 1 October 12, 2004 08:06
Parametric Studies Using Fluent 6.1 Jim FLUENT 0 April 12, 2003 10:22
mixing studies Kai Kang Main CFD Forum 1 July 17, 2000 10:58
