Turbulence model for flow over a cylinder at Re=10000
Like Tree2Likes
  • 1 Post By ghorrocks
  • 1 Post By hee
Old   June 19, 2011, 00:10
Default Turbulence model for flow over a cylinder at Re=10000
ojha.mayank485's Avatar
Mayank Ojha
ojha.mayank485 is on a distinguished road
Am trying to find the Lift coeff, Drag coeff and the Strouhal number for a cylinder in a cross flow at Re=10,000
Things I tried:
1. Created a mesh and ran cases for tstep=0.001, 0.0001 & 0.00001 using KW and SST turbulence model. The y+ for the mesh was around 3.5-4. So now I created another mesh.
2. For the new mesh, the y+ value over the cylinder surface was found to be 0.62. I ran with SST and KW at tstep=0.001 which is 2% of vortex shedding time. The time step is low enough to capture the vortex shedding.
Results:
1. My St number is 0.22 while the expected value from DNS and experimentsis 0.2~0.21
2. My Cd (average) was found to be 1.3 and expected value is 1.1
3. Lift coeff was found to be ~1 while expected value is 0.5 (which is where the real problem is). The value is almost double.
I would like to know if there is anything else I should be doing and where am I actually missing.
Thank you very much.
Ojha
ojha.mayank485 is offline   Reply With Quote
Old   June 19, 2011, 06:51
Are you sure the lift coefficient is based on the correct reference area? Mixing up radius and diameter explains a factor of two.
Now that you have got a model which is pretty close (in everything except lift), if you wish to get more accurate you should do a proper convergence study to guide you into what options you have left. Consider Richardson extrapolation, grid convergence indexes and similar techniques to really squeeze the last drip of accuracy out of it. "Computational Fluid Dynamics" by Roache is the seminal textbook in this area, but a summary of some key concepts is here: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F - and the reference to JFE is highly recommended reading.
Old   June 19, 2011, 12:01
Mayank Ojha
Thanks Glen. Appreciate your feedback.
I had another question. I am using 5% turbulence ( i.e medium intensity) at the inlet. Should this be causing the problem ???
I realize that this problem is slightly tricky because prior to separation, the flow is laminar while after separation its completely turbulent.
How about the BSL model and the non-linear RNG k-e model ? Literature say that they have been proved to be a good estimate for near wall flows and flows with rotation (which is exactly my case). But literature also say that SST should be the best (which it does not, so far).
Right now am running an LES for this case. Lets see how it goes.
BTW what is Richardson extrapolation and grid convergence indexes ??? Looks like the library is out of Roache's txt book.
Old   June 19, 2011, 18:35
If that is not representative of the turbulence levels of the experiment you are comparing to then definitely, yes.
In that case you might want to consider the turbulence transition model. That is the only turbulence model which can account for transition effects.
Have you checked the dissipation is correct? Made sure you are getting the correct turbulence spectrum? Defined the inlet correctly for LES? Unless you have properly set this model up for LES you are kidding yourself. You cannot just turn on the LES option and rerun it and expect to get a reasonable answer.
Looks like you need to find the textbook I referenced then! Also read the FAQ link I quoted and look them up on google. There are other ways besides the library these days.
joy2000 likes this.
Old   June 20, 2011, 13:01
Mayank Ojha
I have never run an LES. Can I have some more details/references as to how to check for dissipation and turbulent spectrum ?
Thanks Glen.
Old   June 20, 2011, 18:47
LES is a whole field of CFD in itself, your library should have textbooks on the topic. Otherwise start with general CFD books (eg Anderson) as they often introduce the concepts of LES.
Old   June 21, 2011, 13:17
Paulo Alexandre Costa Rocha
paulo is on a distinguished road
AFAIK a Reynolds number of 10000 is not fully turbulent for external flows. Pure RANS models are not proper. Maybe LES or a transition model can give better results.
My two cents.
Best regards,
Paulo Rocha
paulo is offline   Reply With Quote
Old   February 3, 2012, 20:49
cfd
wind.cfd is on a distinguished road
I am modelling the turbulent flow over the cylinder by fluent(k-epsilon model)
I have a basic question about defining the boundary conditions for the domain. The domain is rectangular. for specifying velocity inlet for domain, I have to define the turbulent intensity as well as hydraulic diameter, I want to know I should use the diameter of the cylinder as the Hydraulic diameter or the cross length of the inlet face?!
Thank you
wind.cfd is offline   Reply With Quote
Old   February 4, 2012, 05:33
Far
Sijal
You should use transition model for this Reynolds number.
Old   February 4, 2013, 03:44
hee
hee is on a distinguished road
Hi everyone,
I'm running a 3D cylinder simulation in FLUENT with a Re of 100,000. I've used a Transition SST model with a time-step size of 1e-06 and 10,000 time steps. I'm trying to obtain the drag coefficient from this simulation
The results I've obtained shows an oscillatory motion, with the Cd value hitting a peak of 1.21 midway before falling back to 0.726 at the end of the 10,000 time steps.
Can anyone tell me why has this occurred? What do I need to do for the Cd values to be stablised?
Thanks!
Regards,
Hee
emreg likes this.
hee is offline   Reply With Quote
Old   February 4, 2013, 04:10
Your question is about Fluent, not CFX and this is the CFX forum. But the answer is the same: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
Old   May 18, 2015, 20:11
Emre G
emreg is on a distinguished road
Originally Posted by hee View Post
Hi everyone,
Thanks!
Regards,
Hee
is there a solution on this issue please?
emreg is offline   Reply With Quote
Old   May 18, 2015, 21:03
My post #11 is a pretty clear response to this.
Old   May 19, 2015, 02:09
JuPa's Avatar
Mr CFD
JuPa is on a distinguished road
Is zonal RANS a thing? I.e. define two subdomains? A laminar one and a turbulent RANS one?
JuPa is offline   Reply With Quote
Old   December 26, 2017, 08:28
Jennifer Von
Jennifer Von is on a distinguished road
Hi everyone,
Thanks!
Regards,
Hee
I met the same problem as you met. Is there a solution?
Jennifer Von is offline   Reply With Quote
Old   December 26, 2017, 16:29
Have you read the posts which follow it?
Old   June 24, 2018, 09:44
Jinlai Zhang
Jinlai is on a distinguished road
how did you set the Re number as 10000 ?
can you show me the detail ?
Jinlai is offline   Reply With Quote
Old   June 24, 2018, 10:37
karachun's Avatar
karachun is on a distinguished road
Re=u*D/ν, u - speed, D - characteristic length, ν - kinematic viscosity. Vary these three values to get Re=10000.
karachun is offline   Reply With Quote
Old   June 24, 2018, 19:01
CFX is a dimensional solver, it does not use non dimensional numbers like Reynolds number directly. To do a simulation at a specific Reynolds Number you have to select a length, velocity and fluid properties which give the Reynolds Number you want.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Modified k-e turbulence model UDF Travis Fluent UDF and Scheme Programming 7 November 11, 2018 20:21
question about turbulence model selection and sensitivity karananand Main CFD Forum 1 February 26, 2010 04:41
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 03:20
SSG Reynolds Turbulence Model Georges CFX 1 February 28, 2007 16:15
Turbulence model Herry Phoenics 1 May 29, 2003 13:19
