CFX to tecplot for plotting Cp(preesure coeff.) |
June 17, 2011, 02:42 |
Deal all,
I want to plot Cp(pressure coeff.) curve around the turbine blade. When I use a Fluent, I used 'Iso-surface' for getting values at the specific plane. (For example, I got pressure vaules at x-y plane.(z=3)) Then, I exported pressure values to tecplot, and I plotted Cp curve for the specific blade section using tecplot. However, I do not know how to get Cp curve using CFX. I repeat that I want to get pressure values at the specific plane from CFX, and then I want to export the values to tecplot. How could I do this? Please tell me step to step procedure. Thanks and regards. |
June 17, 2011, 08:12 |
Rep Power: 143 |
You can do it lots of ways in CFX. The most obvious seems to be: You could generate a contour of z=3, extract that as a user line and export the pressure from it.
June 19, 2011, 21:28 |
Thanks a lot, ghorrocks.
I got it! But, I still don't know how I could extract it to tecplot form. |
June 20, 2011, 18:38 |
Rep Power: 143 |
Tecplot has pretty simple input formats. Have a look in the Tecplot manuals and edit the exported file in a text editor.
CFX Post vs. Tecplot (xy-graphs) | Tobias | CFX | 8 | October 8, 2010 08:24 |
CFX and Tecplot | ealatawi | CFX | 1 | June 10, 2010 08:07 |
CFX 10.0 to Tecplot in .cgns | Felix | CFX | 3 | June 12, 2006 08:57 |
export CFX results to Tecplot | Cui | CFX | 6 | January 27, 2004 02:55 |
Tecplot & CFX 4.4 | S. H. Kim | CFX | 3 | December 20, 2001 06:07 |
