The process of heat transfer. Pipe in Pipe
Hello, I'm new in CFX, now I need to simulate the heat conduction through the pipes wall. http://depositfiles.com/files/uo5wqn82s
if someone can help me, please write me hottern@list.ru. Thanks http://saveimg.ru/show-image.php?id=...2d5529da18f32fhttp://xmages.net/show.php/2913635_123-bmp.htmlhttp://saveimg.ru/show-image.php?id=...2d5529da18f32f http://depositfiles.com/files/moolme9wb |
Sounds like a straight forward conjugate heat transfer (CHT) simulation. There has been lots of posts on how to do this. Also the tutorial examples are good, I think the heating coil example would be relevant to you.
I'm sorry, but I somehow can not choose two fluids and the temperature distribution in the walls are not visible. If you are not difficult, can help to understand.
http://depositfiles.com/files/ts0gclsnq this is my project |
Please post images on the forum. I cannot see the link you posted.
If you have two fluids then you have a multiphase model as well. Is this correct? |
I don't know how to pick multiphase model
Try the tutorials first.
Hi hottern,
Saw the image posted by you. Your problem is multiphase with heat transfer. Two phases involved are air & water. There are good tutorials to understand the multiphase problems. You may try "Tutorial 15: Multiphase Flow in Mixing Vessel". Good luck. :) -Sanyo |
