June 29, 2011, 07:04 |
The process of heat transfer. Pipe in Pipe
Olga
Hello, I'm new in CFX, now I need to simulate the heat conduction through the pipes wall.
if someone can help me, please write me hottern@list.ru. Thanks http://saveimg.ru/show-image.php?id=...2d5529da18f32f Last edited by hottern; June 30, 2011 at 02:09. |
June 29, 2011, 07:10 |
Rep Power: 143 |
Sounds like a straight forward conjugate heat transfer (CHT) simulation. There has been lots of posts on how to do this. Also the tutorial examples are good, I think the heating coil example would be relevant to you.
June 29, 2011, 09:06 |
Olga
I'm sorry, but I somehow can not choose two fluids and the temperature distribution in the walls are not visible. If you are not difficult, can help to understand.
http://depositfiles.com/files/ts0gclsnq this is my project |
June 29, 2011, 18:08 |
Rep Power: 143 |
Please post images on the forum. I cannot see the link you posted.
If you have two fluids then you have a multiphase model as well. Is this correct? |
June 30, 2011, 02:11 |
Olga
I don't know how to pick multiphase model
June 30, 2011, 03:45 |
Try the tutorials first.
Sanyo
Hi hottern,
Saw the image posted by you. Your problem is multiphase with heat transfer. Two phases involved are air & water. There are good tutorials to understand the multiphase problems. You may try "Tutorial 15: Multiphase Flow in Mixing Vessel". Good luck. -Sanyo |
Pipe Flow Heat Transfer | Saima | CFX | 5 | January 30, 2011 16:41 |
Heat Transfer in a pipe flow(hot air) | Saima | Main CFD Forum | 0 | January 17, 2011 07:08 |
Modeling heat transfer through a pipe | Kristofer | Siemens | 5 | December 5, 2010 14:14 |
Which Heat transfer coeffcient to use? | tengra | FLUENT | 1 | May 1, 2009 13:49 |
heat transfer through fluids in a pipe in pipe | madasu | FLUENT | 1 | July 15, 2002 10:14 |
