-   -   CFX5pre error in ALTIX (http://www.cfd-online.com/Forums/cfx/90310-cfx5pre-error-altix.html)
acoustica July 6, 2011 16:28
I am trying to run .pre extension file with command
cfx5pre -batch test.pre
I using altix environment of cfx5-12.0 version :I am encountered with following error:
An error has occurred in cfx5pre:
CUE Viewer executable
/opt2/ANSYS/v130/v130/CFX/bin/linux-ia64/viewer_ogl.exe does not exist
Please tell me if there is any solution !!
The same thing is working with cfx5-11.0 version ..
ghorrocks July 6, 2011 19:22
Your path is wrong. "/v130/" appears twice in the path.
acoustica July 6, 2011 20:45
no path is correct .. it is my installation directory ..
Lance July 7, 2011 01:56
...um, why? Is the installation done properly?
And you say you use "altix environment of cfx5-12.0" but your path is for version 13?
acoustica July 7, 2011 05:42
ok ..let me put like this....12 or 13 no matter what.. error is same..
/opt2/ANSYS/v120/CFX/bin/linux-ia64/viewer_ogl.exe does not exist
Lance July 7, 2011 06:14
The path to viewer_ogl.exe seems to be OK if /opt2/ is correct.
I would check to see if the installation worked.
acoustica July 7, 2011 06:24
The same test.pre file is working in the version 11.0
Installation if fine.. this viewer_ogl.exe file it self is not there in ALTIX
is there is any options to by pass this viewer_ogl.exe .
acoustica July 7, 2011 06:25
Lance July 7, 2011 06:29
You could perhaps try cfx5pre -gr mesa -batch test.pre
acoustica July 7, 2011 06:53
i tried this also but no use !!
error message is mesa not allowed .. only graphics available ogl ..
and it is switching to ogl ...
stumpy July 7, 2011 08:05
Is ALTIX support only for the solver in version 12? If so, you probably can't run Pre or Post
acoustica July 7, 2011 09:27
But the same thing is working fine with version 11 in ALTIX
acoustica July 7, 2011 09:28
stumpy July 7, 2011 09:41
Look in the doc to see what is supported. Supported platforms change, so just 'cos it worked in 11...
