CFX5pre error in ALTIX
Old   July 6, 2011, 16:28
Default CFX5pre error in ALTIX
Tijery
acoustica is on a distinguished road
I am trying to run .pre extension file with command
cfx5pre -batch test.pre
I using altix environment of cfx5-12.0 version :I am encountered with following error:
An error has occurred in cfx5pre:
CUE Viewer executable
/opt2/ANSYS/v130/v130/CFX/bin/linux-ia64/viewer_ogl.exe does not exist
Please tell me if there is any solution !!
The same thing is working with cfx5-11.0 version ..
acoustica is offline   Reply With Quote
Old   July 6, 2011, 19:22
Your path is wrong. "/v130/" appears twice in the path.
Old   July 6, 2011, 20:45
Tijery
no path is correct .. it is my installation directory ..
Old   July 7, 2011, 01:56
Lance
Lance is on a distinguished road
...um, why? Is the installation done properly?
And you say you use "altix environment of cfx5-12.0" but your path is for version 13?
Lance is offline   Reply With Quote
Old   July 7, 2011, 05:42
Tijery
ok ..let me put like this....12 or 13 no matter what.. error is same..
/opt2/ANSYS/v120/CFX/bin/linux-ia64/viewer_ogl.exe does not exist
Old   July 7, 2011, 06:14
Lance
The path to viewer_ogl.exe seems to be OK if /opt2/ is correct.
I would check to see if the installation worked.
Old   July 7, 2011, 06:24
Tijery
The same test.pre file is working in the version 11.0
Installation if fine.. this viewer_ogl.exe file it self is not there in ALTIX
is there is any options to by pass this viewer_ogl.exe .
Old   July 7, 2011, 06:25
Tijery
Old   July 7, 2011, 06:29
Lance
You could perhaps try cfx5pre -gr mesa -batch test.pre
Old   July 7, 2011, 06:53
Tijery
i tried this also but no use !!
error message is mesa not allowed .. only graphics available ogl ..
and it is switching to ogl ...
Old   July 7, 2011, 08:05
stumpy is on a distinguished road
Is ALTIX support only for the solver in version 12? If so, you probably can't run Pre or Post
stumpy is offline   Reply With Quote
Old   July 7, 2011, 09:27
Tijery
But the same thing is working fine with version 11 in ALTIX
Old   July 7, 2011, 09:28
Tijery
Old   July 7, 2011, 09:41
Look in the doc to see what is supported. Supported platforms change, so just 'cos it worked in 11...
Start cfx5pre and cfd5post with -gr mesa Lance CFX 5 January 26, 2010 03:18
Can't start cfx5pre from Suse 10.2 windhair CFX 1 May 12, 2009 11:32
Installation of OpenFOAM15 on the SGI Altix 4700 LinuxIA64I64DP0pt rhee OpenFOAM Installation 0 November 20, 2008 16:10
Running Fluent on an SGI Altix machine Jonathan Vogt FLUENT 1 March 19, 2008 01:35
Building OpenFoAm on SGI Altix 64bits anne OpenFOAM Installation 8 June 15, 2006 09:27
