Transient flow
Dear all
My inlet is pulsatile pressure . since the inlet is pulsatile , I would like to introduce average mass flow rate at the outlet. How to set average mass flow rate at the outlet as boundary condition Thank you |
What feature do you have to absorb the pulses? Is it compressible flow? Free surface? FSI?
the flow is incompressible.I have a plan to do FSI as well . Thank you |
If you do not know what the average flow rate is then you probably should not use it as a boundary condition. In this case you probably know better what the pressure is, so use a pressure boundary instead.
transient flow
The average flow is the variable at the outlet . so I may vary the flow . If the inlet pressure is pulsatile , The flow is also a pulsatile nature . Am I correct? if this is correct , I want to give average flow over the area . How to set up this boundary condition for this at the outlet ? Thank you Regards Govind |
If you know the average flow then simply assign the exit to be a flow rate boundary with the average flow.
Be very careful that you have properly specified the boundary conditions. I recommend you read the CFX documentation on boundary condition specification to make sure you are heading in the right direction. |
