multi-turbulence model
Old   July 11, 2011, 07:20
Default multi-turbulence model
turbotel is on a distinguished road
hi,
I'm simulating rotating machinery problem.
inlet is mass-flow & temperature.
outlet is static pressure.
after solving (SST - is my turbulence) predicted inlet pressure is 32% more than test data.
what's is the problem?
for this i plan to choose some other turbulence model for stationary (ex. volute..) domains and SST for rotating domain only.
Is that good idea first?
pl somebody help me.
thank you
turbotel is offline   Reply With Quote
Old   July 11, 2011, 19:08
http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
Old   July 13, 2011, 12:17
Abou ali is on a distinguished road
First, you have to verify your machine dimensions especially the inlet and outlet areas then do a mesh sensitivity study, finaly try to obtain an Ypls less than 2 near the walls if you are using SST model.
Abou ali is offline   Reply With Quote
Old   July 14, 2011, 06:36
hi ali,
what is " check machine dimensions especially the inlet and outlet areas"
Pl explain.
thank you
Old   July 14, 2011, 07:52
He means check that your geometry matches the experiment. Other than that all his comments (and much more detail) are mentioned on the FAQ link I referenced.
Old   July 14, 2011, 07:56
ok.
I have not done any changes in CAD model. it's same as test model.
and now i'm trying to find out my discretization error.
thank for your info.
SimpleFoam case with SpalartAllmaras turbulence model implemented nedved OpenFOAM Running, Solving & CFD 2 November 30, 2014 22:43
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 09:02
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 13:57
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 10:26
SSG Reynolds Turbulence Model Georges CFX 1 February 28, 2007 16:15
