July 13, 2011, 15:50 |
Velocity at wall in an internal flow
Ramon Silva Martins
Rep Power: 14 |
Hello, CFX-users.
I've been using ANSYS CFX for a while and I've just found something inconsistent (in my opinion). When I run a turbulent pipe flow and create a line to check out the velocity profile the velocity at the wall is not zero. Of course I've double checked the no-slip condition and the exactly points to create the line. The point is, when I run a laminar case using the same geometry and mesh the flow profile is OK (null velocity at the wall). On the other hand, none of the turbulent cases presents the same behavior. Actually, nondimensionalization of velocity (nondimensionalized by the maximum velocity) presents wall velocities around 0.4-0.5 (which means 40-50% of the maximum velocity). I've been using v. 13.0 and k- turbulence model. I've already tested k- and -RSM turbulence models. I've also tested several y (from 1 to 1000, approximately). I would like to know if any of you has any similar trouble. I thank you for any contribution already. Regards, Ramon Silva Martins |
July 13, 2011, 19:32 |
Rep Power: 143 |
This question has been asked many times on the forum. We should do an FAQ on it some day.
CFX uses control volumes centred on the nodes, so the nodes on the walls generate control volumes whose centroids is off the walls. That is why the wall control volumes have non-zero velocities. To make it display as expected in post processing, CFX has added the "hybrid" variables, where it forces the velocity to zero (or more generally the wall velocity) at the wall. The "conservative" variables show the actual control volume values. |
July 15, 2011, 14:54 |
Ramon Silva Martins
Rep Power: 14 |
Dear Mr. Horrocks,
Thank you very much for your help and explanation. I do thing that this issue deserve a FAQ, due to its relevance. I appreciate your reply. Best regards, Ramon Silva Martins |
July 16, 2011, 06:58 |
Rep Power: 143 |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 15:33 |
internal flow and external flow ? | Pathway0320 | FLUENT | 1 | November 17, 2006 03:37 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 06:18 |
Simple Wall Boundary Conditions for Turb. Flow | Greg Perkins | Main CFD Forum | 4 | May 28, 2002 23:10 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
