June 22, 2011, 10:11 |
Combustion in a Back ward facing step
Mina
Rep Power: 15 |
Dear All
I am trying to model combustion in a back ward facing step for propane air mixture and then compare the result by Robert W Pitz and John W.Daily but the flame shap is really depended on initial condition. First i am doing steady state simulation for Propane Air WD1. First i had problem because the mixture didn't ignite, then i divided the domain to two region and set higher temperature in ignition domain close to the step. but still the flame shap is different with that of the paper. Can some one please help me? Mass fraction of C3H8 = 0.077 Mass fraction of O2=0.4912 Two regions.jpg Temperature.jpg |
June 27, 2011, 05:52 |
Source point in combustion modeling
Mina
Rep Power: 15 |
Dear All
Does any body know about source point? actually i am looking for other way to ignite my mixture because i think ignition zone or using two regins is not good way. i am trying to use source point but i don't know how. can you please some body help me. |
July 10, 2011, 19:57 |
try auto-ignition option
maegasturbine
Are you using the eddy dissipation model? Try using auto ignition and you should be able to get the mixture ignited. The other way of doing it is you can initialize the domain and use a very small value for CO2.mf or H2O.mf = 0.00001 and then run your sim. You should not require multiple domains to ignite. Thanks. |
July 19, 2011, 05:36 |
Mina
Rep Power: 15 |
Hi
Many Thanks. Indeed i am using eddy dissipation and also Finite rate chemistry model and BVM. You mean first i should put both fresh mixture and burnt mixture as an initial value (CO2.mf or H2O.mf = 0.00001 )? i need multiple domains because when i set higher temperature in the whole domain it will be diverged , so i set two domains one which i call ignition zone has higher temperature. but this is not also a good way because in this way the flame will be confined in this domain. I will appreciate if you can give me advice |
July 19, 2011, 05:37 |
Re: auto-ignition option
Mina
Rep Power: 15 |
Hi
Backward facing step; x/H; U/U0; diemsionless analysis; paraview | idrama | OpenFOAM | 1 | December 3, 2013 17:10 |
__Backward Facing Step simulation problems__ | maysmech | OpenFOAM | 2 | February 11, 2011 15:20 |
backward facing step problem | ian8430 | Main CFD Forum | 1 | January 18, 2011 08:58 |
Rearward facing step simulations | siw | FLUENT | 1 | September 23, 2009 02:21 |
Backward Facing Step with Blowing | azar | Main CFD Forum | 1 | November 16, 2006 01:01 |
