Batch Run with Initial values file
Old   July 28, 2011, 02:23
Default Batch Run with Initial values file
KrishnaMohan.Siddu
krrishcfd is on a distinguished road
Hi Everyone,
I want to give batch run in Ansys-CFX on Linux based system. generally i am following the below syntax for defining the batch run ...
#!/bin/bash
#script to run CFX in batch mode
#Change to calculation directory
cd /home/
#start CFX on 4 processors with method MPICH and initial values
cfx5solve -def <filename1>.def -part 4 -start-method "MPICH Local Parallel"
cfx5solve -def <filename2>.def -part 4 -start-method "MPICH Local Parallel"
but if i want to define initial values file also 4r giving the run then how to define the CFXbatch.SH file . (i want the syntax for that)
Thanks in Advance
krrishcfd is offline   Reply With Quote
Old   July 28, 2011, 02:35
This is covered in the documentation, or simply cfx5solve -help on the command line.
Forces in OF15 richard OpenFOAM Running, Solving & CFD 180 July 9, 2018 10:54
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
Negative value of k causing simulation to stop velan OpenFOAM Running, Solving & CFD 1 October 17, 2008 05:36
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 12:53
