July 28, 2011, 14:28 |
CFX for windturbine please help me.
T K
Rep Power: 14 |
Hi there,
I just new for CFX and I am trying to make 3D analysis of 3 blades horizontal axis wind turbine at steady state. I put the domain like picture below I set boundary condition as inlet, outlet, wall (I also set the red zone as wall) and set boundary interface as fluid fluid / frozen rotor. the program is run succesfully but the result that I got is too high (but no that much) I got Cp around 0.52 which is not possible for this design (normally it should be around 0.3-0.45). Dose anyone have better method to develop the domain of this problem. I just thinking to do other domain like the picture below. but I got a problem that I cannot insert domain interface in the orange area. what domain interface I use to use for this area? If anybody has an experience to do 3D WT test please suggest me. I really need your help...I need to make it close to reality as much as I can. Regards |
July 28, 2011, 18:34 |
Rep Power: 143 |
You certainly have the outer tunnel too close to the blades. This will cause a constricting effect on the flow and make the result inaccurate compared to measurements taken in open atmosphere.
Your orange region should work fine as a normal GGI. |
July 30, 2011, 12:21 |
T K
Rep Power: 14 |
Thank you very much , now everything is fine and the results is much more better and reality. And can I ask you another question? I just wann use the results from CFX to import for acoustic analyze but I dont know what function of ansys I have to use.
Regards forgetmenok |
July 31, 2011, 06:53 |
Rep Power: 143 |
I have heard of people linking CFX to SYSNOISE - ask CFX support for details.
July 31, 2011, 10:07 |
T K
Rep Power: 14 |
thanks you very much, I ll try to find it.
Regards |
August 3, 2011, 00:28 |
D
Rep Power: 15 |
If you want to find the noise only a blade pass frequencies then you can export the data using the Dipole function in a transient run found in the exports tab. Then use the data as an input in SYSNOISE or any other such software to evalutae the SPL at BPF Frequencies. Keep the timestep frequency at least 8 times the BPF Frequency to get a passable flow resolution for noise evaluation.
-Dinesh |
August 3, 2011, 17:16 |
T K
Rep Power: 14 |
Thank you,
I have another question... the domain that I set which use frozen rotor I need to set some value of RPM (I know the value) but it seem to give me the answer at steady state of design RPM at any wind speed. I just wonder if there are any method to simulate force acting on the blade and rotate the blade in transient? Forgetmenotk |
August 3, 2011, 17:18 |
T K
Rep Power: 14 |
I mean the output I want to know more are RPM and Torque at anytime, for example t = 10,20,30
August 7, 2011, 10:22 |
#9 | |
Rep Power: 15 |
Angular velocity is not an output. Maybe you should create several def file with diffrent rpm (around design point) and get torque value for each. Then put that values to a chart, trend may gives you an idea about what u want to know. |
August 9, 2011, 04:22 |
#10 |
D
Rep Power: 15 |
if you want to simulate the actual rotation due to wind forces then you need to go for FSI simulation, give the flow as inlet and get the rpm and torque as output. If your domain is completely symmetric about the axis of rotation, you shouldn't find a variation in RPM and torque with time. Only if your input is varying you should get a variable RPM and Torque with time in an FSI simulation. The best way( although a very lengthy one) would be to come up with a operating chart for the wind turbine with delta P v/s mfr at different rpms, and get your result. Initially you can go for only 2-3 rpms and 3-4 mass flows at each RPM's -Dinesh |
August 9, 2011, 06:47 |
#11 |
Rep Power: 143 |
I think you will find working out the fan operating curve using guessed rotational speeds at various wind speeds and loads is faster and more accurate. The FSI approach is not easy.
August 9, 2011, 14:33 |
#12 |
T K
Rep Power: 14 |
Thank you for everybody. I know the RPM at any certain velocity from BEM calculation and that was I did at the first time. Right now I got some problem about the gap between rotational domain and outer domain. I try to vary and simulate its but the results is a bit different and I dont know what exactly length of the gap between that. I might have to try again til I got very close results between two difference gap.
Regards |
January 9, 2012, 12:53 |
#13 |
i am also desighning a simallar model i have made the same domain as your first image. i just want to clarify something: did you get better results by increasing the domain size of your first model in the firs timage?
January 26, 2012, 01:32 |
#14 | |
RS
Rep Power: 14 |
Hi Dinesh, The problem with FSI method is the mesh creation. How to create that Patran Neutral type file which has .out extension as given in tutorial. Does ansys supports creation of such mesh files. If no, which softwares have capability to do such kind of meshes. Thankyou. |
January 26, 2012, 06:05 |
#15 |
Rep Power: 143 |
Patran neutral files come from - Patran, of course. Talk to MSC (or what ever they call themselves now) about Patran.
But I would use the ANSYS meshing tools as they are better integrated into CFX. |
February 6, 2012, 01:02 |
Finding of the power coefficient
#16 | |
LOH AI CHOONG
Rep Power: 14 |
I would like to know that how u are actually extracting power coefficient from CFX? I am doing a similar research, the literature show Cp = (torque*RPM*2*pi/60)/(0.5*density*A*V^3). We pre-set the RPM of the rotor, density , Area, and velocity, and what left is the torque value right? torque value is get from CFX with the function built in? torque_<axis of rotation>@blade right? Thanks alot for the help! Regards, Lacer |
[ICEM] Proper way to name boundaries on 2D model for use in CFX? | RossFS | ANSYS Meshing & Geometry | 4 | November 10, 2011 02:38 |
Pros and Cons for CFX, CFdesign, COMSOL | Val | Main CFD Forum | 3 | June 10, 2011 02:20 |
CFX pressure in Simulations problem | nasdak | CFX | 1 | April 14, 2010 13:22 |
PhD using CFX | Rui | CFX | 9 | May 28, 2007 05:59 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
