-   -   Mesh motion with Translation & Rotation (http://www.cfd-online.com/Forums/cfx/91214-mesh-motion-translation-rotation.html)
Doginal August 3, 2011 16:37
Hello Everyone
I'm currently trying to set up a simulation of a plate translating and rotating in a 2D plane. After reading many other posts I figure using a moving mesh approach is best.
Setup:
Large Square Domain
Inside the large domain I defined a circular Subdomain (this is what I use to move the mesh)
Within the Subdomain there is a rectangular blade
The Square Domain is defined to have Regions of motion specified Mesh Deformation
Boundary Definitions:
Outside Boundary (4 sides of the square domain) has stationary mesh motion
Subdomain has specified location mesh motion using equations
X New Tran
Y Com
Z New
(see below)
Inner Interface boundary (subdomain side of interface) has a specified location mesh motion using same equations as the subdomain
Outer Interface boundary (Square domain side of interface) has a specified location mesh motion using the following equations
X Still = x - Total Mesh Displacement X
Y New Tran
Z New
All other boundaries have unspecified mesh motion.
Mesh Motion:
Case 1: Rotation Only
I started by rotating the subdomain without translation using this thread as a guideline to define the location: http://www.cfd-online.com/Forums/cfx...g-domains.html
These are the rotation equations i have used
X New Rot: ((x-X0)-Total Mesh Displacement X)*cos(alpha)+((y-Y0)-Total Mesh Displacement Y)*sin(alpha)+X0
Y New Rot: -((x-X0)-Total Mesh Displacement X)*sin(alpha)+((y-Y0)-Total Mesh Displacement Y)*cos(alpha)+Y0
Z New: z - Total Mesh Displacement Z
This rotated my subdomain and blade very nicely.
Case 2: Translation Only
Next I translated the subdomain without rotation using these equations of mesh motion
X New Tran: ((x-X0) -Total Mesh Displacement X)+ 5 [cm rad^-1] * sin(1 [rad s^-1] *pi*t)
Y New Tran: ((y-Y0) -Total Mesh Displacement Y)+ 5 [cm rad^-1] * sin(1 [rad s^-1] *pi*t)
Z New (use same as rotation)
This translated my subdomain and blade very nicely
Case 3: Rotation + Y Translation
Next I tried to combine rotation with Y translations using these equations
X New Rot (use same as rotation)
Y Com = Y New Rot + Y New Tran - y
This is where i run into issues. When i use these equations rather than translating/rotating my subdomain, it skews my circle into a oval and rotates and continues to skew the oval. I'm cirtan that its errors in my equations but i'm not sure what from. If i had to guess i'm using the x,y and z variables as well as the Total Mesh Displacement variables wrong as i'm not completely sure of what they represent.
Are x, y and z just the specific x y and z coordinate of a specific node on the mesh to be moved?
Is the Total Mesh Displacement the overall displacement of a specific node from its original point to its current point in the x, y or z direction?
Any help or advice would be greatly appreciated.
Thank You,
DM
alinik January 6, 2014 13:17
mesh translation
Were you able to define translational mesh displacement in CFX? All I can find is rotational motion.
Thanks
ghorrocks January 12, 2014 07:21
Translational motion is a beta feature which I suspect is not fully implemented. Talk to ANSYS support if you want to know the status of it.
