Update Loop = TRANS_LOOP
hello to all.
i want to calculate an integral that depends on time.i need to sum flowrate in all passed time.i defined an additional variabe as follow: LIBRARY: &replace ADDITIONAL VARIABLE: debi Option = Definition Tensor Type = SCALAR Units = [kg/s ] Update Loop = TRANS_LOOP Variable Type = Specific END END and then i run for 1 iterate to initailize debi=0 then i define debi to be equal to "debi+massFlow()@inlet" in the var.value and i use the .res file of the first run as initial condition.when i start run it gives me error but when i edit "debi+massFlow()@inlet" to bo "massFlow()@inlet" it works good.so i think debi is unknown for ansys.......... what should i do? pls guide me in detail. best regards. |
Define CEL expression X=debi+massFlow()@inlet.
And then put debi=X. |
