Total mass flow - CFD Post
Old   July 31, 2011, 14:32
Default Total mass flow - CFD Post
James
James113 is on a distinguished road
I am using CFX to simulate the motion of fluid inside vibrating elastic pipe.
Currently, I am trying to use CFD-POST to calculate the total mass flow through the inlet.
I know how to calculate the total mass flow on each time step, but how can I sum it?
Thanks,
James
James113 is offline   Reply With Quote
Old   August 1, 2011, 10:45
Edmund Singer P.E.
singer1812 is on a distinguished road
Try using perl and powersyntax. The following is an example. Not tested and written in haste, but general idea.
# Load a transient file and read the time step list
> load filename=myFile.res
!$timestepList = getValue("DATA READER", "Timestep List");
!@timesteps = split(/, /, $timestepList );
# Print step number, time value and mass flow for each time step
! $sum = 0;
! open(FH,">myOut");
! foreach $ts ( @timesteps ) {
> load timestep=$ts
! $val = massFlow("Inlet");
! $sum=$sum+$val;
! $time = getValue( "DATA READER", "Current Timevalue");
! print FH "$ts $time $val $sum\n";
!close FH;
singer1812 is offline   Reply With Quote
Old   August 8, 2011, 15:49
James
Thank you Singer. I will try that.
particle, parcel and mass flow rate balance flybird FLUENT 0 May 24, 2007 10:44
mass flow Wenbin Song FLUENT 0 September 27, 2005 13:00
Mass flow rate Neser CFX 4 February 14, 2004 00:27
Determine mass flow rate along flow path Atit Koonsrisuk CFX 2 October 5, 2003 04:47
Mass Flow Inlet Pravir Kumar Rai FLUENT 0 February 19, 2003 14:03
