remeshing due to negative volume error
Old   August 17, 2011, 17:00
Default remeshing due to negative volume error
anonymous
Doginal is on a distinguished road
Hello Everyone
I'm trying to simulate a blade moving with 3 DOF in space (translate along a 2D plane and rotate within the plane). I am using a moving mesh method to do this.
I have a blade with a cylindrical subdomain around it. The outer domain is a large square. I am attempting to translate and rotate the subdomain within the larger domain. This is so the mesh within the subdomain can remain constant while the mesh in the large domain absorbs all deformation as the flow in the outer domain is very minimal.
When i try to move my subdomain at different velocities i run into negative volume errors. I understand this is due to my mesh calapsing on itself. I can avoid the error using a mesh stiffness based on mesh volume size however this causes the mesh to stretch greatly on 1 side of the inner domain and squish on the other (this makes sense as when the mesh increases slightly in size each time step the stiffness will decrease causing it to exponentially stretch).
When i run my simulation using a mesh stiffness based on boundary distance the mesh retains a much better structure however, when i increase the velocity (from 0.5 to 2m/s and up) i cannot get it to finish a run without coming across a negative volume error.
My first question is does anyone have any suggestions as to fix the negative volume error while still using a boundary distance based mesh stiffness. I've played a bit with the time step size but that doesn't seem to fix it.
My second question is if i have to set a remeshing critiria than is it possible to set it to only remesh the outer domain (keep in mind the inside domain is not a different domain but a subdomain) in order to reduce computational time and increase accuracy through not remeshing where the main part of the flow is.
My last question is just about 1 setting. When setting a moving mesh, for my plate wall boundary condition, the "Wall Velocity Relative To" option. Should that be checked? and if so which should be used boundary frame or mesh motion. I'm not quite sure what that means.
Thank You,
DM
Edit:
After examining my mesh further, i can see that the negative volume is occurring further away from the subdomain walls. It seems as though the mesh is folding in on itself to the side of the subdomain (so if it moves in x direction, elements fold in on its self along the y side away from the interface).
Doginal is offline   Reply With Quote
Old   August 21, 2011, 22:50
anonymous
Hey Everyone
Any help is appreciated. Even if anyone can point me towards remeshing tutorials. I've tried to find some stuff but nothing really takes you through it step by step.
Thank You,
DM
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 14:21
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 18:43
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 06:07
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
