Two-phase flow + evaporation
Old   August 21, 2011, 09:51
Default Two-phase flow + evaporation
sberez is on a distinguished road
Hello
I want to simulate air flow over a small (1X1 m^2) open water reservoir.
The air temperature is 35 C and water temperature is 20 C.
The air approaching the reservoir is humid with relative humidity of 70%.
How do I simulate this problem (change in air temperature, increase in air vapor content) to find the conditions after the air passes over the reservoir?
sberez is offline   Reply With Quote
Old   August 21, 2011, 19:29
Mauricio Labarca
mauricio is on a distinguished road
For starters ,You'd need to setup the domain as one gas fluid as a mixture of water vapor + air ideal gas, another fluid as just the water, and then, a binary fluid mixture made of water and water vapor to capture the evaporation between them by antoine coefficients. There's a tutorial with those evaporation settings i think, but for lagrange-euler fluid. In this case it'd be Euler-Euler where both phases are continuous .
mauricio is offline   Reply With Quote
Old   August 22, 2011, 05:09
thanks for your reply, i've made the same settings of the domain but i'm having trouble defining the model, do you have a link to that tutorial or is it made by Ansys?
Old   August 22, 2011, 06:37
Mauricio Labarca
It's the "spray dryer" tutorial that comes with ansys cfx 12.
behavior of two phase flow in a pipe Sonia84 FLUENT 5 September 17, 2013 16:31
Two phase flow in a distributor Mohsin FLUENT 5 May 24, 2010 02:57
Validation for laminar Disperse phase flow shashwat Main CFD Forum 0 April 4, 2008 02:20
how 2 freeze 1 phase flow field & start lagrangian KK CFX 5 February 14, 2008 16:48
low speed compressible two phase flow?? cat CFX 0 November 15, 2005 07:59
