-   -   batch command initial values (http://www.cfd-online.com/Forums/cfx/92327-batch-command-initial-values.html)
test3r September 10, 2011 06:25
I would like to run cfx5solve in command line. At the moment I use the following command for a parallel run:
cfx5solve -def job.def -partition $NTASKS -par-dist "$hostlist" -start-method "HP MPI Distributed Parallel"
I added a solve "execution control" in Pre so that the solver should now that I want to use "double precision" and "initial values".
Now my problem is that I do not see the old convergence plot in my result file as I can see if I use the graphical interface.
Has somebody an idea what is going wrong. Thanks
Yours
stumpy September 12, 2011 11:27
Sounds like you didn't use "Continue History From" with the initial values?
test3r September 12, 2011 15:02
Thanks for your reply! You are right. Next to another box which I forgot to check.
