October 17, 2011, 12:16 |
smoothing the surface
mahdi
Rep Power: 14 |
Dear All
I have a problem. When I model a FSI problem in CFX, during the shape changing, the flexible wall is distorted and zigzag and so, the solution is diverged. I want to smooth the wall during each shape changing. Is there any function in CFX to smooth the flexible wall. |
October 17, 2011, 17:21 |
Rep Power: 143 |
Have a look at the Rhie-Chow options and pressure interpolation schemes. You may need to move away from the default.
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
