Home > Forums > CFX
CFX Post - Vector field lines possible?
Old   September 13, 2011, 23:32
Default CFX Post - Vector field lines possible?
tdpomodoro
tdpomodoro is on a distinguished road
Hi guys,
Been reading the forum for a long time - lots of knowledge here.
I've come across a problem that's stumped me. I'm trying to create a vector plot to visualize the swirling nature of the fluid downstream of a cylinder.
I'd like the arrows joined head to tail, sort of like a an isobar but for velocity?
I've searched through the ANSYS help files to no avail, it seems all that is possible is a field of vectors.
Any help would be much appreciated.
Here's a picture of what i'm trying to achieve:
tdpomodoro is offline   Reply With Quote
Old   September 14, 2011, 02:31
Lance
Lance is on a distinguished road
Um, one way could be to first create stream lines and then create a vector field where you specify location: streamline 1 in the settings for the vector plot. Would that give you what you want?
Lance is offline   Reply With Quote
Old   September 14, 2011, 07:07
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
Another option could be to define the cross section planes then do surface streamlines on the planes.
Old   September 14, 2011, 10:33
tdpomodoro
Thanks for your replies, guys.
Lance, I just gave that a try. Novel idea however I couldn't get it working.
Glenn, I had a play around and I came to that conclusion as well however the results aren't as elegant as in the screenshot I put up previously.
Also, when I apply an arrowhead to the stream lines they point normal to the plane?
Perhaps these surface streamlines aren't actually giving me the vectors in the plane of the plane?
Old   September 14, 2011, 17:24
Bruno
brunoc is on a distinguished road
Glenn's suggestion should work. Try playing with the min and max times and the interval. Use a constant black color. Also, instead of using the arrowhead, use arrowhead 3D and disable lightning at the render tab. That should give you something close to what you want.
brunoc is offline   Reply With Quote
Old   September 15, 2011, 06:52
Sal
Sal is on a distinguished road
Unfortunately, arrows will never be as good as these ones shown in your Fig.6. As far as I am aware, Glenn & brunoc's suggestions are the only available approaches in CFD-Post (at the moment) to solve this issue.
FYI, you can change projection to Tangential on Vector Plot but results are still not as good as those.
Alternatively, you can draw Surface Streamlines on specific cross-section planes (see Glenn thread) without any symbols, and then add 'arrows' using any image editor software.
Hope it helps.
Sal is offline   Reply With Quote
Thread Tools
Trackbacks are On
CFX post legend modification mactech001 CFX 3 December 25, 2011 23:12
Making Lines in CFX Scott Nordsen CFX 2 September 30, 2009 19:36
CFX 11, post Anant CFX 1 June 24, 2008 11:03
Chart Generation in CFX Post Vadim Baines-Jones CFX 2 August 28, 2007 09:14
Tecplot for CFX post processing pantangi goud CFX 2 August 24, 2005 16:42
