March 30, 2011, 11:48 |
Reaction rate too slow
K. D.
Rep Power: 15 |
Hello.
I try to simulate combustion in a porous structure using eddy dissipation model. Convergence is okay, but the reaction rate is too small. The combusion should be (nearly) completed at the burner outlet, but the ch4 mass fraction is only half the inlet value. Is there a way to speed up the reaction? THANK YOU A LOT IN ADVANCE! |
April 6, 2011, 13:49 |
Rep Power: 17 |
Standard values are adjusted to standard cases without porous media. Increase EDM A and EDM B, will increase reaction rate.
- - - - - ------------------------------------------------------------------------ Please do not forget: I am not paid for answering your questions. Thousands of issues can cause a division by zero. Please do not capture a thread, with the argument: "I have the same issue ...." |
April 6, 2011, 13:51 |
K. D.
Rep Power: 15 |
thank you joey!
September 16, 2011, 07:44 |
m
Rep Power: 14 |
I am also trying to simulate reactions in porous medium but i do not get even half conversion of species. I cannot find anything on the internet about mixing rates and how to change them logically. I would be glad if you could give me some insights. Thank you, Mehtap |
Segmentation fault in running alternateSteadyReactingFoam,why? | NewKid | OpenFOAM | 18 | January 20, 2011 16:55 |
UDF for catalyst volumetric reaction, temperature overshoot though rate is small | elmcmaster | FLUENT | 0 | October 11, 2010 09:37 |
surface reaction rate with udf | yellow-stuff | FLUENT | 4 | January 29, 2010 12:53 |
UDF changing the rate exponent of a reaction | Stefan H | Fluent UDF and Scheme Programming | 0 | September 16, 2009 13:20 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 00:07 |
