-   -   Creating ew material's properties. (http://www.cfd-online.com/Forums/cfx/92578-creating-ew-materials-properties.html)
foo7 September 19, 2011 05:20
Hello there.
Well, I'd like to know if it is possible to add new material properties, created by myself.
Thanks!
ghorrocks September 19, 2011 06:14
Yes. Duplicate an existing material in the tree and edit it.
foo7 September 19, 2011 07:00
Sorry, I guess I didn't make myseof clear. What I want is to create a new property for all materials. In a way that I could call it within CEL. For example, I would create a property called PROPERTY_x, ad within CEO I would be able to write: Fluid 1.PROPERTY_x
ghorrocks September 19, 2011 07:36
You cannot do this.
What is the property you wish to add?
foo7 September 19, 2011 07:47
I'm trying to simulate a gas mixture, formed by a few different gas components.
Each component's heat capacity is modeled by the following equation: a + b*T +c*T^2. In which T is the gas phase temperature and a,b and c are coefficients which vary from component to component.
So to have all the components heat capacity calculated I'd have to write the equation for each one of them. What I would like to do is create a set of material properties in which I could store the values of the parameters a,b, and c. And then call them in CEL. This way I would only need to write the equation once.
ghorrocks September 19, 2011 08:00
Sorry, you cannot do this in CEL.
I would simply put the equation a+b*T+c*T^2 in as the heat capacity for each component, with the parameters substituted for a, b and c. Not very elegant but simple and CEL can handle it.
Also this sort of update is easier to do in the expression editor rather than the CFX-Pre GUI. That way you can easily copy and paste sections of CCL and CEL rather than zillions of clicks.
