Home > Forums > CFX
Running simulation until certain condition is reached
Old   September 19, 2011, 07:20
Default Running simulation until certain condition is reached
Benjamin
elys is on a distinguished road
Dear all,
I have looked through the tutorials and made some searching on the net, but I couldnt find a solution to my problem: Lets say I have a bottle with just one outlet (static pressure; 1 atm/Bar) and a steady state analysis type. The pressure in the bottle is set to e.g. 10 Bar (e.g. ideal gas or Redlich/Kwong CH4) and I want to know the physical time passing by when the gas exhausts through the bottleneck. Do I have to set a monitor point of some kind? How do I set the solver control, so that the run finish automatically if the interior pressure reaches the static pressure from the BC?
Any hint would be greatly appreciated,
Thanks in advance!
Ben
elys is offline   Reply With Quote
Old   September 19, 2011, 07:38
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
I do not know the details of what you are modelling but it does not sound like a steady state model. You need to model this transient. Alternately, you may be able to do a series of steady state runs are various pressures (assuming the pressure drop all occurs at the exit) and then use a simple control volume solver to work out the pressure versus time.
Old   September 19, 2011, 08:03
Benjamin
Thanks for your answer, that sounds reasonable. I try both ways, the extrapolation from various stready state runs and the transient approach.
Thanks again for the quick reply!
Ben
Old   September 19, 2011, 19:04
I did not propose an extrapolation from steady state runs. I proposed a psuedo-steady state approach where you assume the transient flow can be represented by a series of steady state conditions.
Thread Tools
Trackbacks are On
GUI crash and simulation engine still running RPJones FLOW-3D 2 November 9, 2010 09:18
how to set up a wall boundary condition according to calculated wall shear stress? gameoverli OpenFOAM Pre-Processing 1 May 21, 2009 08:28
Boundary condition, UDF, Wave simulation hm FLUENT 0 August 2, 2004 21:45
2D simulation as boundary condition for 3D problem Jan De smet FLUENT 1 October 11, 2002 02:02
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 11:06
