Home > Forums > CFX
mesh adaptation
Old   September 19, 2011, 17:20
Default mesh adaptation
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
Dear CFX experts
As I know that we can adapt the mesh in CFX Pre. But I cant find the Y+ in the variable list? Any body has idea how to get the mesh adaptation based on the Y+.
Thank in advance
Far is offline   Reply With Quote
Old   September 19, 2011, 18:33
Bruno
brunoc is on a distinguished road
Hi Far,
I'll have to check on this tomorrow, but I believe y+ is only calculated at walls. If that's the case it is not a volumetric variable and cannot therefore be used as a mesh adaption criteria.
BUT... you could create an algebraic additional variable that calculates y+ manually, and then use this variable to adapt your mesh.
That being said, if what you're trying to do is to automatically refine your mesh based on y+, what you should do instead is manually generate a few meshes with decreasing y+ and compare their results. I don't think using mesh adaption is the correct approach in here, since you won't get a nice, smooth and gradually increasing mesh spacing near the wall by using mesh adaption.
Cheers
brunoc is offline   Reply With Quote
Old   September 19, 2011, 18:44
Far
Sijal
actually my mesh has y+ less two every where except at the leading edge. where it goes to 6 in very thin region. I need to determine the effect of this on my results
Thread Tools
Trackbacks are On
Axisymmetric 2D mesh adaptation - ERROR Pepe CFX 3 May 30, 2011 08:28
snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Native Meshers: snappyHexMesh and Others 2 March 27, 2011 21:11
external flow with snappyHexMesh chelvistero OpenFOAM 11 January 15, 2010 20:43
Can mesh adaptation be used with dynamic meshing? BillH FLUENT 2 July 22, 2007 16:35
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
