[Sponsors] | |||||
irfan
Rep Power: 3 ![]() |
![]() I'm a student doing a final project using CFD. I'm currently new with CFX-post and i'm having difficulties searching for the aerodynamic moment value for my wing. I have learned that the the torque value showed in the function calculator is using the (0,0,0) coordinate as the reference point, but my aerodynamic center isnt on the (0,0,0) coordinate. Is it possible to change the reference point for torque? Changing the geometry to make the (0,0,0) as the aerodynamic center isnt an option for me because it means having to change the blocking/mesh which is quite complex. I have and still searching for this in the helps and tutorial documentation, but having no luck finding a solution. Thanks |
Edmund Singer P.E.
Rep Power: 7 ![]() |
Create a new coord frame. Hit the icon that looks like a coord, and place it where you want, oriented how you want.
Then in the function calc, this coord frame will be available. |
irfan
Thank you very much for your answer. It helped alot .now i have a chance to finish my work ontime. |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Second Derivative Zero - Boundary Condition | fu-ki-pa | OpenFOAM | 8 | July 3, 2011 20:58 |
| Installing OpenFOAM-1.5-dev on a cluster | ZKM | OpenFOAM Installation | 4 | December 25, 2010 15:59 |
| specify a reference pressure point in FD method? | Rui | Main CFD Forum | 10 | August 30, 2010 08:50 |
| OpenFoam-1.7.x on Suse 11.2 (64bit) does not compile | val46 | OpenFOAM Installation | 4 | August 27, 2010 03:43 |
| Calculation of the Governing Equations | Mihail | CFX | 5 | July 25, 2008 17:29 |
