Appropriate convergence residuals?
Old   September 28, 2011, 05:11
Angry Appropriate convergence residuals?
Joe
qsx4881 is on a distinguished road
Dear all,
I am simulating thermal stratification in pipe.
The problem is while the residual below 1e-5, the simulation result doesn’t match experiment result well. But if I enlarge the residual of the energy equation(for example 1e-4), I can get a similar result with experiment.
Is anyone encounter the same situation with me. The problem is?
Thanks in advance!
qsx4881 is offline   Reply With Quote
Old   September 28, 2011, 07:19
You would have to post some results to show what is changing between the two convergence levels.
Also this may help:
http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
Old   September 28, 2011, 14:35
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
the problem is while the residual below 1e-5, the simulation result doesn’t match experiment result
Mesh independence, time step Independence or any parameter in numerical method does not guarantee that your results must match with the experimental data. For example, if you get the good results with coarse mesh and bad results with fine mesh does not mean that fine mesh results are wrong. What is required in numerical methods that you should follow the best practice such as you should make sure that your solution is independent of : mesh , time step , domain size, or any other parameter which you think have effect on the accuracy of solution.
Just assume, if we get the right solution; with any mesh, time step and turbulence model, which is overlapping with experimental data, then there shouldn't be any need of latest research in CFD and even we wouldn't had this sort of discussion any more in CFD-ONLINE
Far is offline   Reply With Quote
Old   October 10, 2011, 08:25
Joe
I had a vacation last week. Thanks for ghorrocks and Far 's reply. I'll have a try about your suggest.
Old   October 10, 2011, 08:59
Far
Sijal
pls do tell us what is outcome. :P
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Convergence issue- residuals of continuity s.garg FLUENT 4 November 7, 2016 11:39
Force can not converge colopolo CFX 13 October 4, 2011 22:03
convergence and residuals ebm CFX 2 February 2, 2009 17:55
Convergence - scaled vs unscaled residuals HS FLUENT 1 November 7, 2005 05:45
