intersection of meshes in centrifugal pump
Old   October 4, 2011, 03:45
Default intersection of meshes in centrifugal pump
ali
eng_norouzi is on a distinguished road
hi everybody
i want to import 2 meshes of a complete pump, impeller mesh(rotating part)and casing(stationary part) but when i import 2 meshes and i want to create the frozen rotor interface between them,meshes have an small overlap region i mean the two side of interface is not connect to each other in this case i think i should use the intersection option in interface window in cfx.now my question is :
what is the best model of intersection for my case?
what happen if i dont use intersection?
thank you
eng_norouzi is offline   Reply With Quote
release of the ERCOFTAC centrifugal pump - Fourth OpenFOAM Workshop olivier OpenFOAM 8 October 29, 2018 07:49
[GAMBIT] influence between angle in impeller blade and centrifugal pump performance barak182 ANSYS Meshing & Geometry 2 August 18, 2010 03:07
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 03:20
centrifugal pump and centrifugal fan Mangesh Main CFD Forum 3 January 3, 2006 11:21
stator-rotor interaction in the centrifugal pump G.H.Lee Main CFD Forum 4 May 25, 1999 07:33
