Home > Forums > CFX
measure the exchange between two pipes
Old   September 30, 2011, 04:04
Default measure the exchange between two pipes
Daniel
Wedge23 is on a distinguished road
For a student research project I have to measure the exchange between two pipes connected by a small gap (picture 1).
I want to measure the exchange in two different ways to avoid inaccuracy. For every calculation I need two runs. First I do a convergence run to get a robust flow. In the second run I take the .res file and use it as an initial file to start a new run with the robust flow.
On the one hand I use a „new Variable“ which I define as 1 in one pipe-entrance and as 0 in the other pipe-entrance and in the two exits. This works pretty good.
On the other hand I want to use two different temperatures in the two pipes. But when I start the second run ( with the „new Variable“ and two different temperatures) the new calculation doesn´t accept the new different temperatures. The temperatures in both channels stay the same as in the convergence run.
Picture 2 is a picture of the „new variable“ I defined. Eventually I want to have a comparably appearence with different temperatures instead of different defined „new Varibale“ values.
My Question is: Does anybody know what’s my mistake or can tell me a different way to do my calculation?
I know my problem is a bit complicated, but i hope somebody has an idea
Wedge
Wedge23 is offline   Reply With Quote
exchange temperature
Thread Tools
Trackbacks are On
Flow around pipes - heat transfer coefficient on the wall of pipe doodek Main CFD Forum 2 November 23, 2009 09:48
exchange properties in VOF mvee FLUENT 0 October 17, 2007 08:45
Add Measure Markings or Coordinates to the Contour Colin FLUENT 4 August 25, 2004 09:54
cylindrical pipes Ben CD-adapco 4 June 16, 2004 11:25
45 degree pipes Amir Habibdoost FLUENT 1 June 10, 2003 12:40
