-   -   Wall scale not converging (http://www.cfd-online.com/Forums/cfx/92994-wall-scale-not-converging.html)
arunraj October 1, 2011 03:44
1 Attachment(s)
Hi all,
Actually I am analyzing the distortion effects on a complete rotor annulus.. So I need to get the compressor map with and without distortion..For this i initially i analyzed the complete rotor model without distortion, i got the compressor model..When I am keeping the distortion screen in front of the rotor..the problem starts, the wall scale is not converging. I am not understanding the problem in this. but THE MOMENTUM , HEAT TRANSFER AND TURBULENCE GET CONVERGING
Ref pressure= 0 pa
Fluid: air ideal gas
Heat transfer: total energy
Turbulence model: SST
Wall function: automatic
Transitional turbulence: Fully Turbulent.
RPM= 1800
1. How can I resolve this problem?
2. Do I have to go for expert parameters?.. I have found so many options in expert parameters reg convergence of wall scale?
I have added the image of model
Hi Glenn, I guess You know it better
Cheers,
Arun
ghorrocks October 3, 2011 17:52
It is very unusual for wallscale not to converge yet the flow equations to converge. Something is wrong with your setup. Is your mesh quality OK? Try a higher quality mesh or running double precision.
