Home > Forums > CFX
Error
Old   October 5, 2011, 04:09
Default Error
oscar
delatorre is on a distinguished road
Hi all,
I have a problem with my simulation. It suddenly stops with the typical problem of overflow but in .OUT file there's omething else which says:
"A wall has been placed at portion(s) of an OUTLET boundary condition (at 100.0% of the faces, 100.0% of the area) to prevent fluid from flowing into the domain.
I don't really understand, I made my solver conditions as robust as possible, playing with the advection scheme and the time step but it does not really helps. Any idea?
delatorre is offline   Reply With Quote
Old   October 5, 2011, 06:35
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
When a solution is diverging (ie the overflow comment) then anything can happen. So flow going backwards is quite possible as the results will be total rubbish.
Old   October 5, 2011, 09:09
oscar
I know...I've read that in cavitation simulation, transient problems converge more easily than stationary ones. Is it true? May I consider to simulate a short physical time rather than wait for a stationary solution???
Thanks in advance!
Old   October 5, 2011, 18:46
Yes, transient simulations are easier to converge that steady.
But it depends on what you want - if you want the steady state flow you will have to run the transient simulation a long time to get there.
Old   October 6, 2011, 03:40
oscar
Yes sure...thank you very much! I'll try then
Thread Tools
Trackbacks are On
GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM 300 October 29, 2014 19:00
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 18:43
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
user defined function cfduser CFX 0 April 29, 2006 10:58
