-   -   vertical gas-liquid separator problem with the convergence (http://www.cfd-online.com/Forums/cfx/93131-vertical-gas-liquid-separator-problem-convergence.html)
juliom October 5, 2011 20:26
1 Attachment(s)
Dear friends, I have worked very hard on my thesis, but I have had problem with the convergence.
The boundaries conditions are:
Inlet: bulk Velocities (volume fraction of each phase)
Gas outlet (upper): pressure 0 psi
Liquid outlet (down): 0.35 psi (hydrostatic)
The model I am using is inhomogenues, specifically the particle model.
I am using the gravity vector due to the fact that I am modelling the gravitational effect (densities difference)
K-E for turbulence...
My simulation starts running but after 25 iteration this message appears :A wall has been placed at portion(s) of an OUTLET |
| boundary condition (at 100.0% of the faces, 100.0% of the area) |
| to prevent fluid from flowing into the domain.
I know what it means, the problem is that I have done several things but the problems continues.
Who can HELP ME ...
Thanks before hand
ghorrocks October 6, 2011 07:09
This might have some tips:
http://www.cfd-online.com/Wiki/Ansys...gence_criteria
juliom October 6, 2011 08:06
Dear Glenn,
I think that my problem is on the boundaries Conditions!!
Have you worked on this sort of problems before????
yours faithfullly
JM
ghorrocks October 6, 2011 18:16
No, but I have a reasonable amount of general multiphase experience.
omem84 October 20, 2011 20:58
Hi. Why are you using CFX? I am working in an oil-gas horizontal separator in FLUENT using eulerian model. I am using 0 pressure in the gas outlet and the oil column pressure in the oil outlet. I am fixing the operating conditions of pressure and density equal to separation pressure and gas density. I going to add you in my contacts to chat about this. Regards.
juliom October 21, 2011 07:45
dear Omen84
I would appreciate your help on this!!
I look foward to contact you soon...
Greetings..
JM
omem84 October 22, 2011 00:18
JULIOM I am not an expert, but I think that we can help each other sharing criteria. I just started a month ago to build the model with the help of CFD "experts" from CAVENDISH Company. This is my email gdg_84@hotmail.com
Regards
