October 17, 2012, 14:37 |
An error has occurred in cfx5solve:
volo87
Good morning everyone,
after several days spent trying to find a possible solution to the problem i decided to ask for help. It seems something for expert and out of my knowledge! I tried the following things: -install again ansys; -install again the license; -install again the graphic drivers; -do the model setup again from scratch; -search if anybody else had the same problem (C000005 seems to be quite common but not with an "aborted for unknown reason" error!) I am currently using ANSYS 13.0, FLUID FLOW (CFX). Here the output message (I now it is long, but I think it is better to give as much information as possible): **************** This run of the CFX-13.0 Solver started at 20:11:06 on 17 Oct 2012 by user volo87 on VOLO87-VAIO (intel_xeon64.sse2_winnt) using the command: "C:\Program Files\ANSYS Inc\v130\CFX\bin\perllib\cfx5solve.pl" -batch -ccl runInput.ccl -fullname "Fluid Flow CFX_021" Setting up CFX Solver run ... +--------------------------------------------------------------------+ | | | CFX Command Language for Run | | | +--------------------------------------------------------------------+ LIBRARY: MATERIAL: Air at 25 C Material Description = Air at 25 C and 1 atm (dry) Material Group = Air Data, Constant Property Gases Option = Pure Substance Thermodynamic State = Gas PROPERTIES: Option = General Material EQUATION OF STATE: Density = 1.185 [kg m^-3] Molar Mass = 28.96 [kg kmol^-1] Option = Value END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = 1.0044E+03 [J kg^-1 K^-1] Specific Heat Type = Constant Pressure END REFERENCE STATE: Option = Specified Point Reference Pressure = 1 [atm] Reference Specific Enthalpy = 0. [J/kg] Reference Specific Entropy = 0. [J/kg/K] Reference Temperature = 25 [C] END DYNAMIC VISCOSITY: Dynamic Viscosity = 1.831E-05 [kg m^-1 s^-1] Option = Value END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = 2.61E-02 [W m^-1 K^-1] END ABSORPTION COEFFICIENT: Absorption Coefficient = 0.01 [m^-1] Option = Value END SCATTERING COEFFICIENT: Option = Value Scattering Coefficient = 0.0 [m^-1] END REFRACTIVE INDEX: Option = Value Refractive Index = 1.0 [m m^-1] END THERMAL EXPANSIVITY: Option = Value Thermal Expansivity = 0.003356 [K^-1] END END END END FLOW: Flow Analysis 1 SOLUTION UNITS: Angle Units = [rad] Length Units = [m] Mass Units = [kg] Solid Angle Units = [sr] Temperature Units = [K] Time Units = [s] END ANALYSIS TYPE: Option = Steady State EXTERNAL SOLVER COUPLING: Option = None END END DOMAIN: CFF Coord Frame = Coord 0 Domain Type = Fluid Location = Assembly 3 BOUNDARY: CFF_GW Side 1 Boundary Type = INTERFACE Location = F771.659 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END MASS AND MOMENTUM: Option = Conservative Interface Flux END TURBULENCE: Option = Conservative Interface Flux END END END BOUNDARY: FREESTREM_CFF Side 2 Boundary Type = INTERFACE Location = F807.659 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END MASS AND MOMENTUM: Option = Conservative Interface Flux END TURBULENCE: Option = Conservative Interface Flux END END END BOUNDARY: ROTATING_W Boundary Type = WALL ///////// I had to cut some code lines since I exceeded the maximum characters allowed! /////////////////// Coord Frame = Coord 0 Domain Type = Fluid Location = Assembly 2 BOUNDARY: FREESTREM_CFF Side 1 Boundary Type = INTERFACE Location = F47.36 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END MASS AND MOMENTUM: Option = Conservative Interface Flux END TURBULENCE: Option = Conservative Interface Flux END END END BOUNDARY: INLET Boundary Type = INLET Location = F39.36 BOUNDARY CONDITIONS: FLOW REGIME: Option = Subsonic END HEAT TRANSFER: Option = Static Temperature Static Temperature = 25 [C] END MASS AND MOMENTUM: Normal Speed = 10 [m s^-1] Option = Normal Speed END TURBULENCE: Option = Medium Intensity and Eddy Viscosity Ratio END END END BOUNDARY: OPENING Boundary Type = OPENING Location = F46.36 BOUNDARY CONDITIONS: FLOW DIRECTION: Option = Normal to Boundary Condition END FLOW REGIME: Option = Subsonic END HEAT TRANSFER: Opening Temperature = 25 [C] Option = Opening Temperature END MASS AND MOMENTUM: Option = Opening Pressure and Direction Relative Pressure = 1 [bar] END TURBULENCE: Option = Medium Intensity and Eddy Viscosity Ratio END END END BOUNDARY: SLOPE_WALL Boundary Type = WALL Location = F41.36 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Adiabatic END MASS AND MOMENTUM: Option = No Slip Wall END WALL ROUGHNESS: Option = Smooth Wall END END END BOUNDARY: SYM1 Boundary Type = SYMMETRY Location = F38.36 END BOUNDARY: TRAILING_EDGE Boundary Type = WALL Location = F44.36 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Adiabatic END MASS AND MOMENTUM: Option = No Slip Wall END WALL ROUGHNESS: Option = Smooth Wall END END END BOUNDARY: UTLET Boundary Type = OUTLET Location = F45.36 BOUNDARY CONDITIONS: FLOW REGIME: Option = Subsonic END MASS AND MOMENTUM: Option = Average Static Pressure Pressure Profile Blend = 0.05 Relative Pressure = 1 [bar] END PRESSURE AVERAGING: Option = Average Over Whole Outlet END END END BOUNDARY: WALL Boundary Type = WALL Location = F37.36 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Adiabatic END MASS AND MOMENTUM: Option = No Slip Wall END WALL ROUGHNESS: Option = Smooth Wall END END END BOUNDARY: YMM2 Boundary Type = SYMMETRY Location = F40.36 END DOMAIN MODELS: BUOYANCY MODEL: Option = Non Buoyant END DOMAIN MOTION: Option = Stationary END MESH DEFORMATION: Option = None END REFERENCE PRESSURE: Reference Pressure = 1 [atm] END END FLUID DEFINITION: Fluid 1 Material = Air at 25 C Option = Material Library MORPHOLOGY: Option = Continuous Fluid END END FLUID MODELS: COMBUSTION MODEL: Option = None END HEAT TRANSFER MODEL: Include Viscous Work Term = On Option = Total Energy END THERMAL RADIATION MODEL: Option = None END TURBULENCE MODEL: Option = k epsilon END TURBULENT WALL FUNCTIONS: High Speed Model = Off Option = Scalable END END END DOMAIN: GW_ROTATING_REGION Coord Frame = Coord 0 Domain Type = Fluid Location = Assembly BOUNDARY: CFF_GW Side 1 1 Boundary Type = INTERFACE Location = F174.146 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END MASS AND MOMENTUM: Option = Conservative Interface Flux END TURBULENCE: Option = Conservative Interface Flux END END END BOUNDARY: GW_STATIONARY_REGION Side 1 Boundary Type = INTERFACE Location = F173.146 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END MASS AND MOMENTUM: Option = Conservative Interface Flux END TURBULENCE: Option = Conservative Interface Flux END END END BOUNDARY: ROTATING_WALL Boundary Type = WALL Frame Type = Rotating Location = \ F147.146,F149.146,F151.146,F152.146,F153.146,F154. 146,F155.146,F156.1\ 46,F157.146,F158.146,F159.146,F160.146,F161.146,F1 62.146,F163.146,F16\ 4.146,F165.146,F166.146,F167.146,F168.146,F169.146 ,F170.146,F171.146,\ F172.146 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Adiabatic END MASS AND MOMENTUM: Option = No Slip Wall END WALL ROUGHNESS: Option = Smooth Wall END END END BOUNDARY: SYMMETRY_GW_1 Boundary Type = SYMMETRY Location = F148.146 END BOUNDARY: SYMMETRY_GW_2 Boundary Type = SYMMETRY Location = F150.146 END DOMAIN MODELS: BUOYANCY MODEL: Option = Non Buoyant END DOMAIN MOTION: Angular Velocity = 50 [rev min^-1] Option = Rotating AXIS DEFINITION: Option = Coordinate Axis Rotation Axis = Coord 0.2 END END MESH DEFORMATION: Option = None END REFERENCE PRESSURE: Reference Pressure = 1 [atm] END END FLUID DEFINITION: Fluid 1 Material = Air at 25 C Option = Material Library MORPHOLOGY: Option = Continuous Fluid END END FLUID MODELS: COMBUSTION MODEL: Option = None END HEAT TRANSFER MODEL: Include Viscous Work Term = On Option = Total Energy END THERMAL RADIATION MODEL: Option = None END TURBULENCE MODEL: Option = k epsilon END TURBULENT WALL FUNCTIONS: High Speed Model = Off Option = Scalable END END END DOMAIN: STATIONARTY_REGION Coord Frame = Coord 0 Domain Type = Fluid Location = Assembly 4 BOUNDARY: GW_STATIONARY_REGION Side 2 Boundary Type = INTERFACE Location = F67.66 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END MASS AND MOMENTUM: Option = Conservative Interface Flux END TURBULENCE: Option = Conservative Interface Flux END END END BOUNDARY: SYM2 Boundary Type = SYMMETRY Location = F69.66 END BOUNDARY: SYMM1 Boundary Type = SYMMETRY Location = F68.66 END DOMAIN MODELS: BUOYANCY MODEL: Option = Non Buoyant END DOMAIN MOTION: Option = Stationary END MESH DEFORMATION: Option = None END REFERENCE PRESSURE: Reference Pressure = 1 [atm] END END FLUID DEFINITION: Fluid 1 Material = Air at 25 C Option = Material Library MORPHOLOGY: Option = Continuous Fluid END END FLUID MODELS: COMBUSTION MODEL: Option = None END HEAT TRANSFER MODEL: Include Viscous Work Term = On Option = Total Energy END THERMAL RADIATION MODEL: Option = None END TURBULENCE MODEL: Option = k epsilon END TURBULENT WALL FUNCTIONS: High Speed Model = Off Option = Scalable END END END DOMAIN INTERFACE: CFF_GW Boundary List1 = CFF_GW Side 1 1 Boundary List2 = CFF_GW Side 1 Interface Type = Fluid Fluid INTERFACE MODELS: Option = Translational Periodicity MASS AND MOMENTUM: Option = Conservative Interface Flux MOMENTUM INTERFACE MODEL: Option = None END END END MESH CONNECTION: Option = GGI END END DOMAIN INTERFACE: FREESTREM_CFF Boundary List1 = FREESTREM_CFF Side 1 Boundary List2 = FREESTREM_CFF Side 2 Interface Type = Fluid Fluid INTERFACE MODELS: Option = Translational Periodicity MASS AND MOMENTUM: Option = Conservative Interface Flux MOMENTUM INTERFACE MODEL: Option = None END END END MESH CONNECTION: Option = GGI END END DOMAIN INTERFACE: GW_STATIONARY_REGION Boundary List1 = GW_STATIONARY_REGION Side 1 Boundary List2 = GW_STATIONARY_REGION Side 2 Interface Type = Fluid Fluid INTERFACE MODELS: Option = Translational Periodicity MASS AND MOMENTUM: Option = Conservative Interface Flux MOMENTUM INTERFACE MODEL: Option = None END END END MESH CONNECTION: Option = GGI END END OUTPUT CONTROL: RESULTS: File Compression Level = Default Option = Standard END END SOLVER CONTROL: Turbulence Numerics = First Order ADVECTION SCHEME: Option = High Resolution END CONVERGENCE CONTROL: Length Scale Option = Conservative Maximum Number of Iterations = 100 Minimum Number of Iterations = 1 Timescale Control = Auto Timescale Timescale Factor = 1.0 END CONVERGENCE CRITERIA: Residual Target = 1.E-4 Residual Type = RMS END DYNAMIC MODEL CONTROL: Global Dynamic Model Control = Yes END END END COMMAND FILE: Version = 13.0 Results Version = 13.0 END SIMULATION CONTROL: EXECUTION CONTROL: EXECUTABLE SELECTION: Double Precision = On END INTERPOLATOR STEP CONTROL: Runtime Priority = Standard MEMORY CONTROL: Memory Allocation Factor = 1.0 END END PARALLEL HOST LIBRARY: HOST DEFINITION: volo87vaio Remote Host Name = VOLO87-VAIO Host Architecture String = winnt-amd64 Installation Root = C:\Program Files\ANSYS Inc\v%v\CFX END END PARTITIONER STEP CONTROL: Multidomain Option = Independent Partitioning Runtime Priority = Standard EXECUTABLE SELECTION: Use Large Problem Partitioner = Off END MEMORY CONTROL: Memory Allocation Factor = 1.0 END PARTITIONING TYPE: MeTiS Type = k-way Option = MeTiS Partition Size Rule = Automatic END END RUN DEFINITION: Run Mode = Full Solver Input File = Fluid Flow CFX.def END SOLVER STEP CONTROL: Runtime Priority = Standard MEMORY CONTROL: Memory Allocation Factor = 1.0 END PARALLEL ENVIRONMENT: Number of Processes = 1 Start Method = Serial END END END END +--------------------------------------------------------------------+ | Warning! | | | | Return value C0000005 >FFFF in parse_rv, treating as not-run. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | C:\Program Files\ANSYS Inc\v130\CFX\bin\winnt-amd64\ccl2flow.exe | | aborted for unknown reasons. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | Warning! | | | | After waiting for 60 seconds, 1 solver manager process(es) appear | | not to have noticed that this run has ended. You may get errors | | removing some files if they are still open in the solver manager. | +--------------------------------------------------------------------+ This run of the ANSYS CFX Solver has finished. ************************* I am not an expert. I did a couple of simulations before but nothing like that has ever happened to me. Thank you very much for your attention. volo87 |
October 17, 2012, 17:43 |
Rep Power: 143 |
Does a simple simulation like the tutorial examples run?
October 18, 2012, 07:56 |
volo87
Yup. Everything runs just fine except for this one. I have no idea of what is causing this error. Next week I'm going to try to run the file at university, let's see if with an older version it works. I will let you know.
October 18, 2012, 09:33 |
Christoph
Rep Power: 17 |
I'm missing stator-rotor interface!? have you disabled "automatic generation of interface". If so, it seems you forget to build that interface. That would explain the error message
November 27, 2012, 05:33 |
ranjith
Rep Power: 16 |
Did you solve the issue. I am getting the same error
June 14, 2013, 17:44 |
Elena
Where do I do this you say?
thank you |
Display Modes | |
Error #001100279 | bharath | CFX | 9 | March 25, 2015 05:31 |
An error has occurred in cfx5solve | pandu | CFX | 4 | August 21, 2012 20:24 |
An error has occurred in cfx5solve: | HMR | CFX | 5 | February 21, 2012 03:41 |
Error in CFX Solver | Leuchte | CFX | 5 | November 6, 2010 06:12 |
An error has occurred in cfx5solve: | yuan | CFX | 1 | June 8, 2008 15:12 |
