November 15, 2012, 08:19 |
Adding and resolve a differential equation
Luigi Gurreri
Rep Power: 13 |
I have a transport equation of a scalar C in which it appears another (vectorial) variable i.
Also I have a differential equation of i: div(i)=0. Can I introduce and resolve this equation in Ansys CFX, or it supports only algebraic equations? |
November 15, 2012, 16:50 |
Chris DeGroot
Rep Power: 17 |
Yes you can add additional transport equations in CFX.
November 16, 2012, 05:52 |
Luigi Gurreri
Rep Power: 13 |
The problem is that I haven't a transport equation, but an additional differential equation to be solved
November 20, 2012, 17:50 |
Bruno
Rep Power: 21 |
Well, is also a transport equation. Do you mean you want to solve only this equation and not the others?
If that is the case, you can add and the following Expert Parameters to your simulation: Code:
FLOW: Flow Analysis 1 EXPERT PARAMETERS: solve energy = f solve fluids = f solve turbulence = f END END Cheers |
November 21, 2012, 06:51 |
Luigi Gurreri
Rep Power: 13 |
I have a transport equation of the variable C, in which there is a term containing i; also, I have the equation div i = 0. So, I have a system of two equation. I don't know how I can solve the latter equation
November 21, 2012, 07:29 |
Bruno
Rep Power: 21 |
You have four variables (C, ix, iy, iz) but only two equations. Aren't you missing two extra equations to close your problem?
November 21, 2012, 08:05 |
Luigi Gurreri
Rep Power: 13 |
I think you're right! Maybe I need others equations. I will study better my problem
add differential equation |
Display Modes | |
Adding adaptive mesh refinement to the forwardStep tutorial | AlphaSheep | OpenFOAM Running, Solving & CFD | 10 | August 3, 2019 15:40 |
chtMultiRegionFoam, adding a member to an existing class (regionProperties) | romain.h | OpenFOAM Running, Solving & CFD | 1 | October 10, 2012 16:05 |
