October 17, 2011, 14:33 |
Determination of physical timescale
Rep Power: 15 |
I am facing some convergence issues with my steady state simulations. In order to get convergence, I followed the steps in CFX manual and at the link: http://www.cfd-online.com/Wiki/Ansys...gence_criteria and used both Autotimescale and physical timescale options. I reduced timescale factor for the Autotimescale option and the actual timescale for the physical timescale option and got convergence by both. However, while trying to estimate the physical timescale, I followed the steps in the above link and plotted the streamlines with time as the variable as shown in the attached figure. The fluid residence time estimate from streamline seems to be order of 1e-1. However, to get convergence, I had to reduce the timescale to as low as 1e-4 i.e. three orders of magnitude lower. So is the fluid residence time not a good estimate of the physical timescale? |
October 17, 2011, 18:25 |
Rep Power: 143 |
The fluid time scales is just an estimate of what is required for convergence. Some need more, some less. The time scale required for convergence depends on numerical stability factors.
When you cannot run at the fluid time scale it is a sign of a numerically unstable simulation. Try to improve mesh quality, check your physics is correct, use double precision numerics or use a better initial condition. |
October 19, 2011, 20:47 |
Rep Power: 15 |
Thanks Glen for your reply.
Display Modes | |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
When to use local timescale or physical timescale | xyq102296 | CFX | 23 | June 25, 2014 08:55 |
Advice on Physical Timescale | Oli | CFX | 0 | January 16, 2007 11:41 |
Controling Physical Timescale | petr | CFX | 1 | January 5, 2007 19:57 |
SST in 2D? | Jesper Sørensen | CFX | 16 | December 23, 2006 09:40 |
